Question about LG Studioworks 700S 17" CRT Monitor
My monitor is black out,indicator lamp also off
    Problem Solver:
  • 5 Answers
Check the video card on the computer, you are not recieveing a signal from the computer. Also, since you do not have a power indicator light showing that the unit is on, there may be a possiblity that something inside has fried. Sometime in the CRT, there is a fuse that prevent power surges, if the power surge is to high, it will blow the fuse to prevent further damage to the unit. If the unit is no longer under warranty, you can open the case and look for the fuse, but be cafeful and do not have the unit plugged in when opening the case. Also, there are capasitors that store electral current and if you touch them you will recieve a shock.
Posted on May 27, 2011
My monitor on my Dell laptop went completely black while I was on it. I have tried turning it off and back on, and the monitor is not working at all
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 26, 2009 | Dell Computers & Internet
When I turn my Toshiba laptop on,it's black
www.ladparts.net
Oct 26, 2009 | Toshiba Computers & Internet
Monitor blacks out
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 12, 2009 | E-Machines eMachines Monitor E15T4
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Acer 4520g minitor blackout
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 14, 2009 | Acer Aspire 3680 Laptop
Display Problems
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 02, 2009 | Dell Latitude 100L Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Monitor Problems
Defective CCFL backlight may has the following symptom:
Mar 30, 2009 | Dell Inspiron 9300 Notebook
Black screen on led
Monitor is going bad. Have it checked by a reputable repairperson.
Mar 28, 2009 | NEC MultiSync LCD1935NXM 19 inch LCD...
Flashing green power indicator lamp.
Check out the data plug- you may have bent some pins.
May 31, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
LG Studioworks 700S 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
