Question about Canon i-SENSYS MF4660PL - 1827B021AA - - Inkjet All in One Printer
My printer gives me this mssg: "paper jam pls..." since he takes the paper and after the paper reaches the heat sink gives me the mssg above I understand that it should be o sensor problem and I have opened the case and looked for those sensors thinking that one could be blocked out. It seems that all the sensors are working though I think it is a main board sensor reader problem or some controller...
SOURCE: Canon pixma mp150 saying paper jam but cant see one
you are a genius, it WORKED!
Posted on Apr 18, 2007
  • 390 Answers
SOURCE: Pixma mp810 paper jam?
Go inside the unit, the jam is most likely to be a very small torn shred of paper, near the carriage roller or similar. Us ea torch if the room is not bright enough, this helps fing it.
Posted on Feb 16, 2008
SOURCE: paper jam
I had this problem the other day. I turned out that I had a small bit of polystyrene foam had got trapped just before the white plastic rollers you can see in front of the toner sponge where the cartridge head runs when you lift the lid to change ink.
I discovered it by noting that on power-up these rollers turn as if to feed paper back into the paper feeder (i.e. "backwards through the printer"), so I tried to see if I could get a sheet to feed backwards and noticed something was trying to stop the right-hand side of the paper feeding in. Soon after I noticed the bit of foam through the right-hand side slot in the white plastic section above the roller. A quick removal with small tweezers et viola!
Posted on Mar 13, 2008
SOURCE: Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
Posted on Mar 25, 2009
  • 499 Answers
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Posted on Jun 09, 2009
When printing an error "13" appear. what is the cause of the error and what could be the posiible solution. pls advise. thanks
Its a paper jam error. Check your printer properly, even a tiny piece of paper can make it to give error 13.
Mercedes Parts
Aug 01, 2012 | HP (2562C) Matrix Printer
My printer gives an error message "paper jam" when there isn't any jam
Paper is nearly always sensed with little, black levers that are pushed out of the way as the paper passes over it. Inkjet printers normally have just one sensor, while laser printers often have three to localize a jam in the paper path. Take out the paper and drum/toner assemblies and look carefully for the levers. See if they wiggle freely. Since they must be delicate enough to be pushed aside by a sheet of paper, it doesn't take much dust to stick one down, giving a false jam reading. A little wiggling and blowing might fix it.
Aug 18, 2011 | Brother Office Equipment & Supplies
Hello, printer(esp5250) showing this mssg: "printer error. remove access cover. clear all paper. attach cover. press ok to continue. " done this about 15 times even tho there is no trapped paper....
There can be a piece of paper left <broken> somewhere between the gears inside the printer.
Try to partial dismantle the printer <remove the covers> and look inside, maybe you will see that piece of paper.
Dec 10, 2010 | Computers & Internet
I AM USING HP laserjet P2055d printer and its giving me an error saying "jam in output bin" What should i do because I cant see any jammed paper?
the last sensor on your printer it is stuck
check fro paper on it or if it is broken
Pls vote me to keep me alive
Nov 23, 2010 | HP LaserJet P2055d Printer
Replace photoconductor unit
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information
hope this helps, good luck.
Apr 29, 2010 | Gestetner DSm725 All-In-One Laser Printer
Hi there
if you are selling tickets for the running over or the sinking can i have one
Daft question / hint are you loading your paper in the correct way up paper has a natural curl when it is heated or dampened
on the site of your **** the will be an arrow that signifys the first side to be printed on if there is no arrow on the packet take the seam side of the **** as the first side
I hope this is usfull i spent 10 years working on printers and copiers and this one raises it head time and time again
Regards Al "Alstech"
May 26, 2009 | Canon PIXMA MP530 All-In-One InkJet...
E3 code error mssg on printer MP160
As you will probably know E 3 on Pixma is paper jam.
Double check that there is no paper inside, and turn printer upside down shaking it a bit to check if there is any small foreign object (screws, pins, coins etc.) stuck inside.
When there is no jam in the paper path, this problem is typically caused by a broken part in the paper feed mechanism, in the page unit.
The paper feeding mechanism has two white plastic gears connected together with a central spring, near to the waste ink tank, at the bottom of the printer.
This are quite delicate, they often get stuck or boken, or you lose the spring, and the printer stays stuck with E3 error.
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Minolta QMS 2300dl
fix your cartridge again to its position .
also check there is not any paper jam.
open back side case of printer then check thee is not any papaper jam.
Nov 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Paper jam
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Jul 23, 2008 | Office Equipment & Supplies
Canon i-SENSYS MF4660PL - 1827B021AA - - Inkjet All in One Printer Logo
old marine
old marine
