Question about Samsung RS2630SH Side by Side Refrigerator
Fridge freezer making a loud buzzing noise - Samsung RS2630SH Side by Side Refrigerator
My Samsung refrigerator (rf263aebp) was making an awful buzzing noise in the rear after only 1 year. I solved the problem by loosening the rear panel that covers the fan. Apparently, it was too tight and was rubbing on something (the fan?) and causing the noise.
Posted on Jun 15, 2011
    Sergeant:
    Champion:
  • 257 Answers
Usually there is Ice build up around the fan that causes this, most of the time it's due to either a bad defrost thermostat or heating element. Another possibility is that the fan is just out of place and needs a little adjustment. If the problem is ice build up you should start by replacing the defrost thermostat . Here is a link on how to..http://www.youtube.com/watch?v=z-h541_14ZE
Posted on May 24, 2011
4 Suggested Answers
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
TheMazz
  • 78 Answers
SOURCE: Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Posted on Oct 28, 2009
Daniel S
  • 4323 Answers
SOURCE: RF263 series Samsung Refrigerator just began
Hi
The sound comes when there is ice build up around the fan and the fan will hit it causing this sound. You can try to leave it unplugged for around 4-24hrs and also make sure that the area near the back is clear so that airflow can get through. If the issue returns then replace the thermostat. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 01, 2011
My haier fridge freezer is making a loud buzzing noise. Any ideas what it is and can it be repaired
Depends what type of buzzing it is?
It may be an alarm telling you something.
It may be a mechanical buzzing from a motor, relay or solenoid.
Check your manual so see if it has alarms.
Google
make model manual
or visit the Haier website
Some do have an over temperature alarm like this one, so check that the freezer door is properly closed and not impeded by frost build up.
Fridge Freezer
Jul 04, 2016 | Haier Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
1,487 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
