Question about HP Color LaserJet 2600n Printer
The Magenta cartridge on my 2600n is leaking toner onto the plastic conveyorbelt/ screen thingy and so each sheet has a red streak down it. Can anyone help?
  • HP Master
  • 1,915 Answers
The only solution is to replace the magenta cartridge with a new one.
Posted on May 25, 2011
My son-in-law is a computer and cash register repairman. He checked my printer out and thinks that I have a bad charging device problem. Black print works great, but colors just will not work. Blue toner...
The error code 10.0002 is a problem with the magenta cartridge. To be precise it is a e-label error.
The e-label is a small circuit board on each of the cartridges.
Pull the magenta cartridge and clean it.
Now as to the ETB (that's the big mylar sheet with the cyan toner all over it). Get rid of the cyan cartridge, it's obviously dumping toner. Remove all the cartridges and the ETB, and vacuum out the printer...with power off.
Power the printer on and when it comes ready
1. press the select button(check mark)
2. press the - and the 'cancel job' button together (at the same time). release both
3. press the select button. You now should be in the 'secondary menu'.
4. press either left or right arrow buttons to navigate.
5. navigate to CLEAN ETB
6. press select(check mark) and let the machine do its' thing.
Good Luck
Do get rid of the cyan and probably the magenta.
Feb 15, 2011 | HP Color LaserJet 2600n Printer
My hp colour laserjet 1200n printing red background
The magenta toner cartridge is probably defective. If you take the cartridge out and open the flap and see magenta toner all of the drum then it needs to be replaced.
Sep 04, 2010 | HP Color LaserJet 2600n Printer
I have a red streak on the page coming from my hp color laser Juest 2600n
are you sure the colour is not magenta,if so replace the magenta toner
May 15, 2010 | HP Color LaserJet 2600n Printer
I have a HP laser 2600n and it is streaking magenta horizontally.
Sounds like the red cartridge was removed or tilted and leaked toner on the drum. Just do a self clean and it will clear up. It in the maintenance menu.
Mar 07, 2010 | HP Color LaserJet 2600n Printer
Leaves streaks vertically on paper changed cartridge still there. 2600n printer
when you open the front of the print you will see the streaks on the black transfer sheet.
Close the front door half way or until all the cartridge doors open.
You will see the same streaks on the problem cartridge(s) as on the transfer sheet.
Change that particular cartridge, let the printer recalibrate, and presto streaks are gone.
Feb 13, 2010 | HP Color LaserJet 2600n Printer
Cartridge Leaked
Yes it is. Just change the magenta and it will be normal.
Feb 03, 2010 | HP Color LaserJet 2600n Printer
My HP 2600N doesn't print the red and I tried to use 3 new toner but it still don't work. It's not the toner problem and it's the printer. My HP warranted is expire. What should I do? Thanks!
HIgh probablility that the DC Controller has had it. This is an increasingly common fault with the HP1600, 2600, 2605, Canon LBP 5000 and 5100 machines all based on the same engine. The DC Controller puts the charge on the cartridges. When it fails the Magenta cartridge is the first affected and the result is - No Magenta ( reds, oranges, violets etc.) The DC controller must be replaced.
Dec 04, 2009 | HP Color LaserJet 2600n Printer
My hp color laser jet2605dn has a brand new magenta ink cartridge yet does not print the red in pictures on my brochures
One solution is to make sure you have removed the orange plastic strip from the toner. The cartridges are sealed with a plastic strip when shipped and it needs to be removed from the toner side before installing.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
I have a HP 2600n Laserjet... When I print a sheet my red toner seems to bleed in the paper that I am printing on...
Try doing a few calibrations.If this doesnt work then change the Magenta cartridge. It sounds like the cartridge is faulty.
Jan 03, 2009 | HP Color LaserJet 2600n Printer
Red toner leaking onto "spongy" rollers and down onto the paper trays
Hi, its sounds like a faulty magenta cartridge. Contact your supplier for a replacement
May 13, 2008 | Ricoh Aficio CL2000N Laser Printer
HP Color LaserJet 2600n Printer Logo
232 people viewed this question
Seeker5211
Seeker5211
