Hello, I have a Panasonic TH-50PZ800U Plasma. Recently I tried to power it on and got the blinking red light. I unplugged it, waited, plugged it back in and then it would turn on. This worked twice and now I just get the blinking light after some internal clicking noises. The light blinks twice, pauses and repeats. I initially assumed it was a power supply issue but then read on a couple of forums that the 2-blink code was a bad 15v SOS D Board. I bought a new D-Board from topjimmy.com Part #:TNPA4439BJS - http://www.shopjimmy.com/panasonic-tnpa4439bjs-d-board.htm And a new Sub Power Supply, also from topjimmy.com Part #: ETX2MM704MGB - http://www.shopjimmy.com/panasonic-etx2mm704mgb-sub-power-supply.htm After verifying that the parts and numbers were identical, I began by installing the Sub Power Supply. Same symptom and error after installation. I then installed the new D-Board and again got the exact same problem and 2-blink code. Did I change out the wrong part? Any help would be greatly appreciated. Thanks
  • Richard Zessin Sep 04, 2012
    Do you still have one of the d boards, we may be interested in buying it form you. Richard 0411721413
  • 2,098 Answers
Hi Aaron,
2 blinks error code is definitely a 15VDC SOS detect, but this error code does not means that the fault was came from the D board alone. Remember that this is a supply voltage issue also. In the service manual, stated there that the test point is in the D-board (not specifically replaced the D-board).
Let me know the reading in the connector (P25) pin #1&2 in the D-board to assist you further.
Also just for the confirmation of 5vdc, let me know also the reading in (P25) pin #5&6 in the D-board.
Note : to have an accurate reading, place the test prod of your multimeter on the test point prior from powering on the unit because the supply voltage will cut-off after the self test.
Jdvillanueva
Posted on May 24, 2011
Wont power on red light blinks
These blinks are fault indication. From the number of blinks occurs at one time switch on, you can get an idea about the faulty section circuit inside it. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Panasonic Plasma Displays are given in detail.
Apr 07, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic th-50pz800u shuts down and i can not turn back on, red light flashing 2 times, sometimes 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Jan 19, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
I have a panasonic th-50pz800u. I am unable to turn on my tv from my remote or the power button on the tv. I noticed this only happens when the power indicator red light is flashing. I resolved the problem...
Dave,
Im having the same problem. I've had my tv for 1 yr 6 months. How long have you had your tv for? I do the exact same thing you do to fix the problem. Obviously its not a permanent solution. If you find the answer to the problem please let me know. I'm holding out as much as i can before i take it to a repair place and pay the rediculous prices.
Jesse
Jan 01, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic th-50px60u power indicator is blinking 10 times
There are two guides, one for 10 blinks at power on:
or, 10 blinks at plug in:
Jul 24, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
May 23, 2009 | Panasonic Viera TH-42PX80U Plasma TV
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
