Question about General Heating & Cooling
On a Dimplex Cavendish CSH 20 the smoke effect and lights do not operate. What should I be looking for\r\nNeil
    Brigadier General:
  • 4,736 Answers
Right off hand, I'd say the light bulbs are burned out and need to be replaced. The model you listed comes in 2 editions, one with a misting effect and the other without. In both, the bulbs are replaced the same way - by opening the sump door to access the bulbs.
To further help you, I have included a link to the Owners Manual for your model. You may download and print it for future reference.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/Cavendish_Chesford_Opti-myst_Issue_1.pdf
Hope this helped you resolve the problem. Please let me know. Thanks.
Posted on May 24, 2011
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
How do you change the light bulb in a dimplex gem 20 heater?
Hi, First ALWAYS disconnet from the mains!
To change the bulb on your Dimplex you'll firstly need to remove the log effect, there are 2 small black head pozi type screws hidden at the front one on the left and one on right which your bulbs are under situated in their holders (as there are 2 of them) they are mini screw types as opposed to the standard baynot type replace the defective bulbs with like for like once fitted reconnect the mains and try if working, JOB DONE! Page 14 on the link shows exactly how to do it Regards Steve.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
Aug 07, 2014 | Dimplex Compact Electric Flame Stove...
How to reset the switch CNET CSH-1600
No manual. Maybe a pinhole reset switch?
Mar 28, 2014 | Cnet (CSH-1600) (CSH1600)
Flame effect dimmed on my dimplex stockbridge stove
You most likely have a couple light bulbs burned out. Refer to your owner's manual on how to access the bulb area, and replace with the appropriate watt bulbs. Most Dimplex stoves use standard incandescent 60w bulbs, a few use halogen. This is often annual maintenance.
If you can't find your manual, you can request one to be emailed to you from Dimplex, their service line is:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Dec 18, 2012 | Heating & Cooling
Where can a fuer dbg 2-5w 230v ac 50hz 15rpm motor which operates the flame effect on my dimplex fire be purchased
You can buy it directly from the Dimplex USA website. Make sure you have your Model Number handy.
Feb 16, 2011 | Dimplex Compact Electric Flame Stove...
Motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Feb 02, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Heating & Cooling Logo
793 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Bill Long
vance jones
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
