Question about Westinghouse LTV-32w3 HD Television
I need a firmware update for my LTV-32w3 - Westinghouse LTV-32w3 HD Television
  • 103 Answers
SOURCE: picture blurry on my Westing house LTV-32w3 HD Television
hi possably is the fan in the back make shour it is working all the time that there is no dust bild up on it stops it from spining it may need a cleen ,or it is a transister heeting up and cooling down the transister is on its way out it will be a hard fix for a tech to fined thay will fined it but it will cost you a heep ,its best to whate till its gon completly .cheers peter
Posted on Apr 05, 2009
  • 3 Answers
SOURCE: my westinghouse lcd tv ltv-32w3 hd
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Posted on May 14, 2009
my tv says no signal, and everything is just blank. my tv is a samsung 27, and it doesn't say anything. we tried everything like rebooth, and all that stuff. but it doesn't work plzzzz help!!!
Posted on May 31, 2009
budmrtn
  • 11361 Answers
SOURCE: problems with ltv-32w3 hd
You need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller): http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
You cam see the one I fixed here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
Posted on Dec 28, 2009
budmrtn
  • 11361 Answers
SOURCE: my ltv-32w3-hd tv shows mostly blue jumps around n
I would suspect bad T-CON board, see my pictures here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 10, 2010
Ltv 32w3 coax disabled
Google the model number with "manual" to try to locate the owner manual which if the set has such a feature (not likely) will tell how to unlock it.
My guess is set has a bad tuner etc and someone just wanted to dump it on you.
May 31, 2012 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Westinghouse LTV 32w3 HD LCD TV (LTV32w3HD)and it does not come on. I know it is getting power as when i unplug from the wall i can hear a noise.
hi;
its sounds like a loose solder or high voltage leak inside your LTV
if you know how to open the back cover or technical experience to troubleshoot
you can check the power supply board and inverter board if it has a loose solder
you can visualize it in the back of the board.
also check the wires connected to inverter boards if it has a leak.
or shorts.
Aug 28, 2011 | Westinghouse LTV-32w3 HD Television
We have a westinghouse lcd 32w3 hd and when we hooked up a hdmi for the first time the screen went black and no picture or sound, how do we fix this?
If everything but the HDMI is working, its a possibility that the source has a compatibility issue or your TV needs a software/firmware update needed
Aug 01, 2011 | Westinghouse LTV-32w3 HD Television
Problems with ltv-32w3 hd After TV is on for 15 to 30 minutes the picture looks fuzzy and looks like a picture negative but still has color
Nov 28, 2009 | Westinghouse LTV-32w3 HD Television
I am having problems with my Westinghouse LTV-32w3 HD TV. If flickers and rolls kind of like the old tube tv used to roll and you would have to adjust it in the back by turning the nob. I have a 37 inch...
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Nov 25, 2009 | Westinghouse LTV-32w3 HD Television
Picture blurry on my Westing house LTV-32w3 HD Television
Apr 05, 2009 | Westinghouse LTV-32w3 HD Television
Freezes during auto programming
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Feb 09, 2009 | Westinghouse LTV-32w3 HD Television
Televison & Video Logo
163 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
