Question about Soleus 30-Pint Dehumidifier
How do I remove the cleanable filter? I cannot find the manual for my Soleus dehumidifier.
    Brigadier General:
  • 4,736 Answers
The filter is located on the right aside of the unit, behind the louvers on the front. To remove it, look for the finger hole on the side and pull the filter out. You can either vacuum the filter or wash it in tap water. If washed, be sure it's thoroughly dry, before reinserting it into the unit. CAUTION: Never remove the filter with the unit ON.
Below is a link to the Owners Manual, that you may download and print for future reference.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1305703058935/pdf/ownersmanuals/edgestar/DEP400EW_manual.pdf
Hope this helped you solve the problem. Please let me know. Thanks.
Posted on May 24, 2011
What does E5 mean on Soleus Air dehumidifier?
hi Randal.
this is all i could find on the internet.
Your dehumidifier has sensors to monitor for various conditions that may prevent the unit from operating in a normal manner
problem,the led display is showing e5, possible cause,over current protection..solution.unplug for 10.minutes then turn on the unit and if the e5 is still showing contact customer services or a dealer.
you could try this link as well to see if its of any help to you.
What does E5 mean on Soleus Air dehumidifier Google Search
Dec 03, 2017 | Soleus Dehumidifiers
My soleus dehumidifier keeps tripping my fuses on my powerstrip so we have to keep resetting it. Why?
If it is a GFI protected powerstrip then you likely have a ground fault issue, otherwise the powerstrip may be overloaded (unit should pull around 5 amps on startup) or faulty.
Sep 25, 2011 | Soleus CFM-40 Dehumidifier
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
Soleus Air Dehumidifier Model CFM-25E has stopped working after about 1-1/2 years.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 21, 2011 | Soleus Dehumidifiers
My 40 pint Soleus dehumidifier doesn't pull any water into the tank even though the fan blows normal.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jun 18, 2010 | Soleus CFM-40 Dehumidifier
Soleus CFM40E
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
contact@soleusair.com
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Soleus 30-Pint Dehumidifier Logo
190 people viewed this question
Top Soleus Dehumidifiers Experts
jeff5may32
john h
AZBen
AZBen
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
