Hafler 9270 stereo amplifier produces no audio when powered up and connected to speakers. So far, I have only checked the fuses, but am lost as online articles show continuity on my multimeter, however the reading hovers between 0 Ohm and high 100 Ohms or so. They don't appear to be blown. I have a basic knowledge of electronics, but am determined to solve this problem with some extra help!
    Brigadier General:
  • 8,546 Answers
0 ohms is a dead short. That's bad unless you're measuring a single conductor end-to-end.
Register and download the SERVICE Manual for free at retrevo.com
http://www.retrevo.com/support/Hafler-9270-Amps-manual/id/23316bh035/t/2/
Did it ever work?
If not, EVERYTHING is on the table as a possible cause. This is a big dumb amp with nothing but a power switch. Perhaps your source is the issue. Or the stereo/mono switch.
If so, what preceded the failure? Did a control get touched? Smoke?
The Hafler could be protecting itself.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the SOURCE volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Posted on May 24, 2011
Which input for laptop audio?
You can connect a powered stereo speakers or amplifier to your laptop for better sound. Connect an audio cable from the headphone socket on the laptop to the powered stereo speakers or amplifier audio input.
Jul 01, 2012 | Toshiba Computers & Internet
12 volts to amp, when connected no volts, it turns on in my friends car.
The ampliflier require an amount to power volts to perfrom. You friends car may have a power stabilier installed to produce appropiaet supply to stereo systesm. usually, a direct wire from the engine to the amplifer may least function as manufacturers default specifcation. If the amplifer performs at all, a fuse is blown to protect the devices in wiring cuircuits. if the device functioned in another car, it is not damaged. Consult with an auto electrician to attain appropiate wirign or acqurire the component parts to wire the vehicle. Important notes. Each device usually will have an instruction on installing. However, the power source from engine depending on type of vehicle may require regulators to share the current to stereos amplifiers and speakers.
Jan 29, 2011 | Clarion APA450 Car Audio Amplifier
How do i install the movon bluetooth car kit, i lost the manual
The entire devinces of hardware have to be installed to attain power functionality before bluetooth is attainable. First, install new stereo into the socket area with appropiate wiring links attacked to power cuicuits. Second, install the woofers speakers into places firmly attaching to copartments. Connecting links to the stereo that would be produce media with woofer into speakers. Third, once the stereo devices are connected ready to produce the first audio effects, bluetooth is capable of beign set with the features on the stereso.
Jan 28, 2011 | Car Audio & Video
The stereo in my 2001 mercedes slk 320 produce no
hello,good day,try to check your number 14, for your left and rigth speaker amplifier control module,also try to check the fuse in your amplifier,ty
May 12, 2009 | 2001 Mercedes-Benz SLK-Class
Lost low end
Fuse don't break when the blow. If they blow you get NO sound, not distorted sound.
I think you need to bite the bullet and move on with isolation of the (probably dying) woofer. Remove it and swap it with the other one to prove it. Observe the polarity of the + and - wires on the back of the woofers.
Apr 27, 2009 | Audio Players & Recorders
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Hafler power amp has one side out. Would like local repair.Series 9300.Approx.10-15 years old.Not used much.Second time to blow.Runs 4, 8om speakers including 2 bose 802,s (no bose controller or eq in...
just discovered same problem with my Hafler DH-200...right channel out but no obvious problems inside (no loose/burned wires, components, etc). Driven by Hafler pre-amp, but definitely power amp problem.
Sep 03, 2008 | Audio Players & Recorders
164 people viewed this question
 Grubhead
Grubhead
