Question about HP Photosmart 8150 InkJet Printer
Hi, i have a new computer and im wanting to print but have no idea where ive put the cd for my hp photosmart 8150...? Please tell me theres a way i can use my printer stil by not having the cd..?
    Scholar:
  • 157 Answers
Sir,
First take the adapter,power plug put to power socket and othe side connect to printer.then take the datacable and connect one side to printer an other side to pc.then Pls put the cd in your cd driver,it will autorun,then press install and keep on NEXT and finish.then give the print.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Posted on May 24, 2011
How can i get my HP 8150 to print in color? I think this is a problem with my laptop (Compaq) because i have two printers and they both will not print in color from this computer. Please help
Open a document or type something into wordpad,then go up to file,then print.Select the 8150 and go to properties.Somewhere in there,you'll see an option to print B&W or color.Make sure it isn't set to B&W.Should work with your other printer too.
Bob
Aug 10, 2010 | HP Photosmart 8150 InkJet Printer
Lost power to printer
Fumbled around, plugging and unplugging power cords of printer and computer and unplugging printer from computer. Turned off then restarted computer. Printer power came on, but have no idea what did it. Thanks for checking.
Dec 30, 2009 | HP Photosmart 8150 InkJet Printer
My HP Photosmart 8150 will only print from the card reader. When I try to print from the computer, it reads "printing" but eventually times out.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Nov 27, 2009 | HP Photosmart 8150 InkJet Printer
Paper jam warning. I cannot find any paper in
Please try to turn off your printer and unplug all the connection in the printer from its power down to its usb or parrallel connection. And let it up to 30 minutes to unplug and turn off. This process is letting your printer reset it self and loading its default and original settings. Usually it loads it original settings. After 30 minutes please plug all the connection of the printer and then turn the printer on and test the printer by printing a document or any files you want to print. Please observe what is the result.
Thanks
Aug 07, 2009 | HP Photosmart 8150 InkJet Printer
I have a Hp Photosmart 8150 Printer and Lost the CD
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=397810&
Jul 10, 2009 | HP Photosmart 8150 InkJet Printer
My HP Photosmart 8150 has started printing color
You may have a colour management problem. Your monitor may need to be recalibrated from the software you are using to print your images. Your printer too may need to be sorted by calibaration too.
Jun 13, 2009 | HP Photosmart 8150 InkJet Printer
Thin black lines on some of the photos I print on my 8150 photo p
align the ink cartridges and clean the heads. change your printer settings when printing photos to more dry time, less ink and quality to normal
Apr 26, 2009 | HP Photosmart 8150 InkJet Printer
I have lost the installation cd to the hp photosmart 8150 printer
yes. follow this link and choose your operating system to get to the downloads page - HP Photosmart 8150 downloads
From there, download and install the driver, then the application. Good luck!
Dec 17, 2008 | HP Photosmart 8150 InkJet Printer
HP 8150 Wont Print in color
Hi i have simular problems i think. i did getting a fault on my cartridge and the fault message i getting tells me that something is wrong with cartridge and printer will print in backup mode by takeing away the black cartridge, i did try to change to a new black cartridge and the same problems appear.
After some investigating of this problem it seems to be a kind of delikat on my printer, inside where the black cartridge should be placed there are a metall "feather/spring" this has losen at one time i dont know when. but this sharp metall "spring" have been pushed in when replacing cartridge and made a hole in white elektrical connections for this particular cartridge and may damage this connections, maybe this has happend with yours printer as well.!?
And know how to fix this, with no support left at HP there arent so much to do i believe i have to use cartridge with triple color or trow this one away and buy a new one. Use and trow away with blessing from HP.
Aug 26, 2008 | HP Photosmart 8150 InkJet Printer
Problem scanning pictures
Check your documents folder under My Scans. I found that my scans were going in there. I had to open them to put them where I wanted them.
I also have the problem of the missing line up upload to my computer. If I restart the computer with the 6280 on the line reappears and I can scan what I want. I have asked HP what the problem is with no real solution. They seemed to think that since it works after restarting the computer that the problem was solved. The option shouldn't disappear from the screen at any time, but I guess I'm stuck with restarting the computer every time the problem comes up. Hope this helps.
Jun 30, 2008 | HP Photosmart C6280 Printer
HP Photosmart 8150 InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
