Question about LG Televison & Video
LG Model 22LE5310 Sporadically turns volume down and locks remote. Only way to fix is to turn power off at the wall.
5 Suggested Answers
  • 286 Answers
SOURCE: ViewSonic N2750w 27 in Volume turns down by itself
Could be a problem with the down volume button on the tv. the board it's on ir its harness. Check them all. Make sure the volume buttons plastic actuator moves freely and is not stuck.
If these parts are all good, you have a problem on the main board. You may have to trace the control lines as far as you can and check any capacitors along the way. If you have an oscilliscope you can test the lines to see if the up volume is working correctly. If there is noise on it, you might find a bad capacitor if you can trace it back far enough. Schematic helps here.
Of course, make sure nothing is shining on the sensor window on the TV. You might want to scope that line as well (IR sensor line).
If none of that helps, get hold of Viewsonic and find your closest service provider. You can order a main board from them.
Of course, you could try just using the audio out jacks to an amplifier or a surround sound amplifer. Then you would use the remotecontrol for the surround sound system to control your volume.
Bet you were going to buy one anyway right?
Posted on Feb 14, 2008
SOURCE: Remote control does not work for my plasma tv
I also had this same problem. Both the original remote and my universal remote failed to give any response on the TV. Normally the green light flashes when it receives a command from the remote. Called LG Support and they made me an appointment with a local repair company for 3 days later. This seemed pretty quick compared to other companies repair times I'd read about. However next day the repair company called to say it would be 5 more days before they could get a Tech to my location (downtown ATL). 8 days was a long time to wait but once tech arrived he diagnosed it to a bad board and simply went to his truck and swapped it out with mine under factory warranty. Everything has been fine since.
Posted on Jun 04, 2008
SOURCE: syntax lcd tv Model LT26HVX
Throw the TV away and vow to never buy something from this manufacturer again.
They not only refuse to help me with the same problem, but they lied to me and created a false comment on my file.
My TV did this only a few days out of warranty. I called them, not expecting them to warrant it, but to possibly give me some ideas for the problem. I spoke with a manager who volunteered to repair it "just this one time" even though it was officially out of warranty. I thanked him over and over, but the next day, suddenly no one 'knew' the conversation took place. They told me they would investigate (on July 2), and I waited until today to call them and they told me that their notes said I was advised that I would have to pay for repair. They told me of a conversation I had on the 3rd with Ed. There was no conversation with anyone on the 3rd, and no Ed.
This company appears to be sleazy. I'm sticking with Sony or another company from now on who tells the truth.
Posted on Jul 09, 2008
  • 6 Answers
SOURCE: Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Posted on Apr 11, 2009
How do I hard reset my locked LG phone
Hi Cassie
  1. Turn off the phone completely.
  2. Press and hold the Power button and the Volume Down Key.
  3. When you see the LG logo release the Power key, but keep pressing and holding the Volume down button until the factory data reset screen appears.
  4. Once you see the reset screen release all of the keys.
May 01, 2016 | LG Cell Phones
I have a LG VS980W The white one, Verizon 4G LTE. When I power it on, it only shows the Verizon logo and nothing else. what needs to be done to it to make it work again?
The only way to fix the issue is by performing a factory reset and you will lose all of your downloaded apps and data.
To do a factory reset perform the following
1 Turn phone off
2 Press and hold down Volume down key plus Power/lock key together
3 Re;ease the Power/lock key only when the LG logo appears, then immediately press and hold the Power/lock key again.
4 Release all keys when the Factory data reset screen is displayed
5 Press the Volume key up or down, highlight yes and press the Power/lock key to continue. If you want to cancel highlight no and press Power/lock key.
6. Press the Volume key up or down and highlight Yes and press Power/lock button to confirm. Once confirmed the phone will restart and should be fixed.
Hope this helps.
Jan 13, 2015 | LG Cell Phones
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
My sanyo remote model DS27510 won't turn my tv on or off
do you mean you can use only the remote in channel and volume settings but can not use to turn off the tv. ok the problem is just only the power button for the remote. what you need is to clean the rubber contact inside using with an eraser. to do just unclip the lock of the remote controller to remove the housing and to access the internal part.
Jul 21, 2012 | Televison & Video
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have ATT U-Verse and the LG LFD790 Home Theater System. I can program the U-Verse remote to turn the LG on/off, but can not control volume from U-Verse remote. Do you have any codes I can try?
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Dec 30, 2008 | LG LFD790 System
Unable to control channels or volume
Is the remote a universal? Make sure you select TV as the the device you are trying to control. You can also fix a wonky remote by popping out the batteries and mashing down all the buttons. This rids the remote of any built up electricity that could be hampering functionality. Also, the remote sensor on the TV is controlled internally of course so a power drain of the TV wouldn't hurt:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
What do the buttons on the TV itself do? Do they work properly? If not, the problem is going hand-in-hand with the remote and again, the problem is internal and service or a firmware update, if available, may resolve this.
Sep 20, 2008 | LG 42LG50 42 in. LCD HDTV
My dvd shows prog 200 and wont change
FIXED! LG DAT-250W INSTRUCTIONS: TURN OFF THE MAINS POWER AT THE WALL UNPLUG ANTENNA FROM THE BACK TURN POWER BACK ON AT THE WALL & START AS NORMAL IT WILL COME UP WITH "POOR SIGNAL" THEN WE FLICKED THROUGH THE CHANNELS & TURNED IT OFF AGAIN AT COMPONENT & AT THE WALL PLUG THE ANTENNA BACK IN TURN EVERYTHING BACK ON Note: **Just avoid the channel that keeps locking up** LG are aware of this issue
Sep 30, 2007 | LG Televison & Video
Televison & Video Logo
37 people viewed this question
Computer Repairing
Computer Repairing
