Question about Miele H4900B Electric Single Oven
The alarm keeps going off when i try and put the oven on or adjust the temperature
My Baumatic BS65MS oven is cooking too hot, it burns everything. I have turned down the temperature, this doesn't help. What would be the problem?
You may have a stuck thermostat and that should be replaced because he's probably telling the other keep eating even though the temperature the temperature would be correct
think your new oven is too hot or too hot or too cold, you can adjust the temperature yourself to meet your specific cooking preference. You can also adjust your thermostat if your oven is not new, since thermostats may "drift" from the factory setting over time. See the "Adjust the Oven Thermostat"
Mar 18, 2018 | Baumatic Ovens
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
My old admiral oven doesn't get to the temperature I want, could it be the oven temperature sensor?
  1. You can do a simple at-home test.
  2. Purchase an inexpensive oven thermometer (the kind that hang from the rack are great but whatever is designed for oven).
  3. Then set your oven on 350 and wait for oven light to go out (indicating it is at temperature). Compare the temperature on the thermometer (it should say 350 but sounds like your results will be less).
  4. If it is not the same temperature you have SOME adjustment that can be made. Most oven temperature control switches have the ability to adjust/calibrate. Depending on make and model you may be able to pull the temperature adjustment knob off and see a screw and a slot. Loosen the set screw and turn the post slightly then re-seat the screw.
  5. Repeat the test on step 3 again and see if you are closer.
  6. If it got worse, loosen screw and turn the other way (and re-test).
  7. If it got better but not quite right, repeat the procedure.
  8. If you are unable to adjust to get the temperature correct you may have a faulty temperature sensor.
Nov 03, 2014 | Ovens
Why does my oven thermometer read less than the temperature the oven is set at?
An oven doesn't go to the temp selected. That is the average temp. If you set it to 350, it may drop to 300, then to 400, but will maintain an average of 350. Without knowing your model #, it is hard to say. Some have anticipator (that anticipates the temp and controls the heater and the thermocouple that is trying to keep the temp steady. Some models have an adjustment at the oven switch (rear) that can be adjusted for temp up or down.
Oct 20, 2014 | Ovens
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
The oven keeps blinking F2 what does that mean
F2 Heating mode high temperature This alarm is activated when the ERC senses a runaway heat condition or when the temperature exceeds "runaway limits". The ERC will beep until the cancel or another function is selected. If the alarm repeats the F2 code check the oven sensor and wiring after first checking for a stuck relay. If alarm goes away verify the oven will complete a clean cycle without any type of failure.
Nov 25, 2010 | Dacor Ovens
I have moved into a house about 11 years old. I started the self clean and now about two hours into it an alarm is going off signifying "F2 door locked". Can't turn off alarm :-( Don't know part...
F2 During CLEAN The Control is senses oven temperature above 915F-930F. If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC). If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches. Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jun 03, 2009 | GE Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Miele H4900B Electric Single Oven Logo
64 people viewed this question
Top Miele Ovens Experts
Paul Bade
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
