Question about Siemens Dryers
Its making noise,clothes are tearing,what to do.
  • Siemens Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on May 26, 2011
Dryer was running but had a very large load. Dyer stopped and now there is a loud clicking sound. We are allowing the unit to cool down. But at this point it will not start have checked all the lint...
Sounds like a pulley wheel inside your dryer, that means tearing down, an some dryers tear down different, pry top with a flat screwdriver, to open top off, spin dryer tub, it should make the noise, if so u have to tear tub out, there's a belt Tincher next to the motor on bo
Oct 10, 2014 | Dryers
Electrolux gas dryer snagging clothes
Good Morning Friend,
I understand your Electrolux gas dryer, model# EIGD55HIW, is snagging and tearing your clothes. There is a possibility that the temperature is too high and you are overdrying your clothes. Make sure to dry your clothes on the correct temperatures and correct times. The other possibility is, the finish inside of your dryer has been scratched or chipped. This can cause a snagging or tearing of clothes. To prevent further scratching and chipping of the drum finish, make sure to always remove any foreign objects from pockets before laundering, as well as make sure zippers and fasteners are not hitting the inside of the drum. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIGD55HIW Gas Front Load Dryer...
The fan is making squeaky noise. Is there a way to quite it down? Can i use WD40? Thanks
try to dismantle shaft and use clothe to wipe out the grease then apply WD40 if the problem persist try to replace your bearing or the bushing a new one possible wear and tear of it cause the noise.
Mar 11, 2011 | Heating & Cooling
Tturn on dryer,clothes do dry,,but dryer makes loub knocking noise
drum rollers/glides, idler pulley, belt, or motor. here are two websites first rollers/glide, second the idler pulley, belt and motor. Good Luck Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 06, 2011 | Dryers
It sounds like the in side drum is loose. It makes a lot of noise when drying clothes.
Oct 30, 2010 | Dryers
My clothes dryer is making a rattling noise. How can I find out if it is worth fixing or getting another clothes dryer
check these parts:
Oct 29, 2010 | Dryers
Hotpoint wf640 makes too much noise whilst spinning level of machine is balanced perfectly makes same noise on every selected speed
sounds like the bearing but could also be the drum support bearing more likely discontinue use until it is sorted or it will collaspe completely or you will experience black oil marks on clothes or tearing, if in guarantee call the manufactuer.
Mar 31, 2010 | Washing Machines
GE front loader keeps tearing clothes
You are overloading if that is all that it happens .....less clothes more water and set the cycle for delicates...... unless the clothes are coming out stuck around the agitator than thats a different prob....
Jul 22, 2009 | GE Washing Machines
Clothes get caught between frame and drum
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Dec 21, 2008 | Dryers
Dryers Logo
151 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
