Question about Motorola Mobility RAZR V3i Cellular Phone
My battery seems to low batt easily - Motorola Mobility RAZR V3i Cellular Phone
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 139 Answers
Hi, when a phone battery is always to low and it does not stay long to power the phone,You might need to replace the phone battery.
Phone batteries has cells inside them that determines how long the battery life will last..When these cell dies, it will be unable to power up the phone for too long and the phone will go off..
To solve the problem of charging a battery and not lasting too long,you will need to replace the phone battery with a new one.
You can get a replacement battery battery from nearest outlet store around your area...
Warning before you buy a new battery, make sure that the phone does not get hot when you insert the battery inside the phone...Because that is not a battery fault. It's a phone board problem.
Take care and thanks for using fixya...
Posted on May 24, 2011
Car wont carank but all electronics work
It seems your starter is in need of some service. Bring vehicle to a mechanic and ask if they can repair it. Check battery cables and clean it, sometimes build up from batt. acid and lead prevent batt. cables from connecting and delivering enough voltage for the starter to crank up. It looks green in nature but it could also be foggy white substance around batt. terminals. Other than that, your batt. must be low in voltage and needs to be recharged. Hope this helps :)
Jun 14, 2015 | Cars & Trucks
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
WHAT DOES BATT LOW MEAN AND HOW DO I FIX IT
Batt low means battery low. CHarge it or change the battery
Apr 28, 2013 | Music
Hello, MY 2005 Nisan frontier will not start. About 3 days ago, the battery light would stay on after the engine started...had the battery checked and it was fine...then serviced it yesterday but it still...
Battery might seem fine on a routine check, but the crancking amp power is not there anymore, seems that your alternator is not charging it anymore, have the alternator checked and replaced if needed, the battery might need replacing too.
Aug 23, 2011 | 2005 Nissan Frontier
My honda civic 1996 model has a new battery while i was driving i felt the light is dimmer than before the radio begin to on and off the oil gauge and the speedometer drops to zero then when i stop the...
It sounds like you have a charging problem-alternator is not recharging batt when drive, batt will only go so far before it runs out then you get your symtoms. you would need a volt meter to double check this. Fully charged batt will be about 12.7volts once car is started and running you should see about 13.8 to 14.2 volts at batt terminals if alt. is chariging batt. the other item that can cause this is the volatge regulator that controls alt. which are sometimes built-in alternator and sometimes they are external to alternator. and of course make sure your belt is turning alternator to allow it to work. One other small note if you do the engine running test-somtimes- if your car idles low(600 or 700 rpm) you need to give a little throttle (1000-1200rpm) to make sure alternator is turning fast enough for output test.
Feb 06, 2011 | Honda Civic Cars & Trucks
C-350 zoom keeps showing low battery and beeping when opened to take pic, but in menu mood shows full, 2 new batteries
I have the same problem but not as grave.
The set can click two to three pics before low batt.
Seems to be a problem with the flash capacitor.
Try with flash turned off the thing should improve.
Nov 22, 2010 | Olympus Camedia C-350 Digital Camera
2000 sunfire charging system
Alternator is bad or the voltage regulator. Both are easily tested. Remove the Alternator and have it tested at Auto Zone or O'Rielley's.
Jun 18, 2010 | 2001 Pontiac Sunfire
Short battery using NiMH batteries
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Sep 28, 2008 | Canon PowerShot A85 Digital Camera
LX7 Mouse False Low Battery Reading
I have found that sometime these Rodents seem to have a "Taste" for a certain "Type" of AA or AAA cell, one needs to get the Highest Discharge rate one can get. Often the "Brand" of Batts supplied are the "Only" ones that seem to work 100% alla time? I have had similar problems with customers B4, and I find the Varta series of battery to be great. & remember just because you bought them "New" don't mean the Batts are always "Fresh", get batts from a place that has a high turnover.
Aug 10, 2007 | Logitech LX7 Cordless Optical Mouse
Motorola Mobility RAZR V3i Cellular Phone Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
