Question about Cell Phones
My nokia n73 phone is dead how to solve this problems
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 139 Answers
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Posted on May 24, 2011
N73 function keypad dead pl.help
My Dear Brother Your Phone Keypad Ic Default So please change Keypad ic and Keypad problem will solved
Dec 19, 2012 | Nokia N73 Cellular Phone
Unabel to perfome bluetooth opration
First try antivirus to scan ur phone... I would recommend u to use f-secure.. if this do not solve ur problem Try hard resetting ur phone... still its notworking means bluetooth ic is dead . Take it to the nearest nokia care centre.
Oct 30, 2011 | Nokia N73 Cellular Phone
I am anand ihave n73 keypad problem i change keypad ic after changing set dead what would be the reason
hy u better check your phone in the mobile service shop the is a small connection between keypad and display if the connetion is cutted means you will get this problem it may take 150 to solve your problem so check there
Oct 11, 2010 | Nokia N73 Cellular Phone
Nokia n73 sim card not valid problem
sim card not valid in my nokia n73 mobile
Mar 05, 2010 | Nokia N73 Music Edition Smartphone
My N73 aint working at all i updated a software and it got hanged now its nt even starting
Dear Ashad , your phone software not done proper Updating. Result is phone software corrupted and dead. Only one solution Just Visit Nokia service center and tell then to install the updated software for your Nokia N73. Problem will solve then. If your handset not on at home you can't fix it by yourself.
Thanks & waiting for your feedback.
Feb 06, 2010 | Nokia N73 Cellular Phone
For Nokia N73 series phone, it says the memory is full & dead slo
don't worry u can formet your phone your problem will solve.first phone off then hold these key in keypad green button{call button} and 3 number and * button hold and press these buttons then start your phone when cell complete on then relese these key your phone clean and neat thx
Sep 17, 2009 | Nokia N73 Cellular Phone
How can I solve my n73 phone that automatic shutt off?
VIRUS PROBLEM TURN ON MOBILE DAIL *7370# CALL CODE 12345 IMRAN 9880400390
Aug 19, 2009 | Nokia N73 Cellular Phone
Tempted to update my Nokia N73 and DIED
Brother, The dead phone is dead by all means. if it is in warranty then go to Nokia care and claim for replacement.
Jun 23, 2009 | Nokia N73 Cellular Phone
Nokia n73 hang problem, I have also done hard set several times,but problem is not solved
Normally Nokia N73 get hanged when its phone memory become very low.Try deleting some data from your phone memory.If it doesn't helps please update your phone's firmware.
Jan 25, 2009 | Nokia N73 Cellular Phone
Cell Phones Logo
73 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
