Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and turned on.
The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows
system tray can cause the HP All-in-One to lose some of its scan
functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Place your original print side down on the left front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it.
3. Make any edits to the preview image, and then click Accept when you are finished.
To stop scanning
➔ Press Cancel on the control panel.
If this doesn't work for some reason you should also be able to scan using windows camera and scanning wizard, the link will show you how if you have XP, just scroll down past the "how to print" section.
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
or this if you have Vista:
If you cannot find the scanner wizard it could be because your version of vista doesn't have it, I'm not 100% but I think it was only packaged with the business version of vista.
If this is the case then you can download a free program called IrfanView from there site:
http://www.irfanview.com/
Click the Start icon.
Click All Programs .
Click Windows Photo Gallery .
Click File and then click Import From Scanner or Camera .
Click Import .
Click Scan .
If this is the case then you can download a free program called IrfanView from there site: http://www.irfanview.com/
I hope that helps..
Regards
Mike
Exactly as described
i have this problem too and it's driving me nuts!
