Hello, I do not know if my other query was sent successfully, so I will do this again. I have an epson aculaser c8500 which I have not used for quite sometime. I tried to print something today and it is still working okay, except that I noticed that the printouts are not as crisp as it used to. There are some areas on the printouts that are faded or washed out. Do I need to perform a nozzle clean? How do I do this. Thank you so much. kyliedee
    Top Expert:
  • Office Equip... Master
  • 12,962 Answers
Go into properties area of printer then services and clean the print cartridges.
Posted on Jun 20, 2017
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: yellow ink does not come out.
Its possible that your printer is fooled to think that the yellow ink level is lower than it really is. not uncommon. Have you changed the different carts on different occasions? You should try resetting the printer. I can tell you that the stylus 500 is reset by turning off, then back on while holding down the Load/Eject button, can't say if it will do the trick on your r300. BTW - epson printers do not like refills or generic - they will clog. I ran across the following cleaning method on the web, it might help you: "Follow this procedure AT YOUR OWN RISK for all I know I may have damaged my printer irreparably, but it does not appear so.) With the power off I manually moved the print heads to the left exposing the pad under the color head. I used several cotton swabs to soak up as much old ink from this pad as I could. I then liberally applied rubbing alcohol to the pad with a cotton swab. About three swabs worth, saturating the pad. I manually returned the print head to *exactly* the same position it was originally in. I turned on the power. This activated the cleaning sequence. (You might also want to press the color head cleaning button to make sure that at least one cleaning cycle runs with the alcohol on the pad.) I turned off the power. Then, while holding down the color cleaning button, I turned the power back on. This activates the self test. By the time the printing of the second sheet of the test was half way completed I had all my colors back."
Posted on Apr 23, 2006
SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Posted on Oct 25, 2007
SOURCE: Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Posted on Nov 13, 2009
nonontech
  • 4737 Answers
SOURCE: Problem for Epson AcuLaser C8500
This error code is displayed when there's a temporary "data error", means transferring data from computer to Printer to make the print outs.
It could be a corrupted or interrupted print job. It's also possible that the Data cable (usb cable) is loose or not properly connected on the computer or on the printer.
Try the following Steps:
First of all, disconnect usb cable from the printer and from the computer (unplug both the ends of the cable) Leave it Off for few minutes and then print a test page or status sheet. (do this before you connect it to the printer) Verify that there's no pending print Queues in the Print Status, if so Cancel them. Now reconnect the usb cable to the computer and on the printer. You are ready to test the printer.
If there's memory installed, please reseat it. Sometimes it's important to restart your computer. So I would suggest you to restart your computer while you keep the printer off.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 23, 2010
Where can i find a epson Aculaser Y dev unit from please
The Y toner cartridges are still being produced by Epson. However not many stores in UK stock them. They are readily available on eBay. You will have a choice of originals or compatibles, and a choice of standard or high capacity cartridges.
I normally stick to originals, and pay around 20 UK pounds for standard and 40 UK pounds for high capacity ones.
Compatibles are about half of those prices, but I have found wide variation in quality.
If you are not using a lot, then originals are preferable.
Let me know if I can be of further help
Trevor
May 14, 2014 | Epson Aculaser C1100 Printer
Printer Driver for Linux : Epson C1000
Hello
Try these links.
driverscollection.com/?...ACULASER%20C1000...Epso... - United States
support.epson.ru/upload/library.../howtoinstallprinterdriver_linux.pd
www.downloadsarea.com/Free_driver-epson-aculaser-c1000-linux/
http://www.dataentryjobs.us/67948.html
Feb 09, 2012 | Office Equipment & Supplies
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
Aculaser 8500 error e525
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Feb 19, 2010 | Epson AcuLaser C8500 Printer
Replace epson aculaser toner cartridge
Try this:
http://files.support.epson.com/pdf/cx11n_/cx11n_pg.pdf
Good Luck !
Jan 24, 2009 | Epson ACULASER CX11NF All-In-One Printer
Paper Jam at A but nothing there
If you clear the jam and close the machine up again, does the print job eventually print OK. You may have to clear the jam several times before the machine prints it successfully. After the first successful print, does the machine then print ok, until the next time it is left idle for some time? If this is the case, I have a fix for you
Nov 07, 2008 | Epson AcuLaser C3000 Printer
Epson aculaser c1100
What you hoovered off is the developer. This is required by the print process. Hoovering it off means there is no way for the toner to get onto the paper. You must replace all the developer units and possibly the toner too. It will be cheaper to by a new printer i think.
You could try a claim on your insurance if you are covered for accidental damage.
In future, maybe you should call an engineer - it is usually cheaper than a new printer.
Nov 06, 2008 | Epson Aculaser C1100 Printer
I got the info through an Epson Eng I know. You should be able to get a replacement item by contacting Epson directly.
Sep 01, 2008 | Epson Aculaser C1100 Printer
Epson aculaser c 1100
What was the service error code It would look something like Service Required E510. This show on the panel and/or in the status monitor
Without this code all we know is your printer has something wrong with it.
Sep 14, 2007 | Epson Aculaser C1100 Printer
k24674
jasbo
jasbo
