Question about Samsung Cell Phones
The battery is fully charged but the phone does not turn on
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 139 Answers
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Posted on May 24, 2011
Tip
First Use of Your Battery
Got a new phone? Before your first use, fully charge its battery without using it, when it's turned off. If the battery comes charged, first empty it completely and then fully charge it when it's turned off. This will extend your battery's life.
on Jun 11, 2007 | Nokia 3220
How I know my lg lsp 350t has full charged
When your lg lsp 350t is fully charged, it stops reading like it is charging. You can also turn off the phone and plug in the charger, once it is full, the battery meter will turn blue or show battery full. \but when the phone is on, the way you will know that it is fully charged is that the battery shows a full bar and does not charge anymore.
Hope this information helped.
Jan 14, 2011 | Cell Phones
My jank phone, incapable of charging, turned off and wont turn on
As the phone keeps turning on off there is some loose contacts or some dirt is there at battery terminals try cleaning phone and battery contact terminals
Jul 21, 2009 | LG VX5200 Cellular Phone
Fully charged cellphone battery drains in a few minutes
relpace your mobile battery and avoid overcharging and charging overnight
May 22, 2009 | Motorola Mobility MOTORAZR maxx V6...
My i9 will not turnon
right no1 the phone comes with 2 batterys which have charge try the other battery if that doesent work connect the phne via usb to a computor it should turn on automaticaly and start to charge then you should after a few min be able to turn phone on fully keep you battery fully charged dont let it completly run down as these phones are prone to this problem
Jan 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
P168 - shut down
try wiping off the connections n hold button down for a min.
Oct 17, 2008 | Dual Electronics CECT P168 Cellular Phone
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
110 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
