Question about Sony DCR-SX40E Camcorder
I have a sony dcr-sx40e and it suddenly has a problem focusing and it is flashing the error message e:61:10. Do you know what I should do to fix this problem? Thanks...
  • Sony Master
  • 17,970 Answers
This applies to this camera series but I found that the E:61:00 means "Difficult to adjust focus Inspect the lens block focus reset sensor". The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
Symptoms:
· After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
· Camera would extend the lens but not be able to focus on anything past 8 inches or so.
· Zoom in and zoom out would not work.
· Playback mode and the Setup mode was not affected.
Solution: This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
Additionally, here is a video of the normal power up sequence of the camera and there other moethods:
1. Here is the first alternate method
2. Here is the second alternate method
Hope this helps.
Posted on May 24, 2011
I have a sony camcorder. Model no.: DCR-SR47. Recently it is flashing the error message on the view screen. The error message is E:61:10. I think the error message is for focusing beacuse my focus is also...
According to the self diagnostic system it shows that the problem is bit critical and it needs to performs the operation by an expert, so you are requested to please contact any expert nearby, moreover, for your better understanding please see the pic below.
Thanks
Oct 22, 2010 | Sony DCR-SR47 Camcorder
Hi, I have a sony handycam dcr-sr32 camcorder fault code E61:10
Either focus motor or zoom motor not working so that error code E61:10 fashing
Mar 10, 2010 | Sony Handycam DCR-SR42 Camcorder
My camcorder can't focus, and I got a message
the display screen is distorted. I can't see anything,
Jan 02, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
Error called E61:00 on my sony dcr-sr35
The problem you told is little bit difficult and it needs expertise, anyway telling you the diagnosis and also suggest you to contact any expert to resolve the problem, the detail is given below:
Error E61:00 description is:
Inspect the lens block focus reset sensor (pin 7 of CN5101 on the VC-518 board) when focusing is
performed when the focus buttons of the touch panel are pressed in the focus manual mode,
and the focus motor driver circuit (IC5401 (Non MEGA model) or IC5301 (MEGA model) on the VC-518 board) when focusing is not performed.
Thanks for using fixya.
Jul 23, 2009 | Sony Handycam DCR-PC109 Mini DV Digital...
Sony DCR-DVD403 camcorder - picture won't focus. E:61:10 error.
E61:10 is a lens error code. You have a bad lens unit, but sometimes they can be fixed. The focus and zoom motor worm drives on the zoom lens jam when they get dropped. If your really really carfull you can free them up and fix the lens. Thereis a plastic claw that rides along the worm drive shaft that can get jamed. I've fixed thousands of these but i'm a guru. It can be tricky.
Dec 09, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
Error message
hi i have the sony DCR-PC53E camcorder with the error code E:61:10 does anyone have any suggestions on how to fix this problem any help will be more than appreciated
Apr 17, 2008 | Sony Video Cameras
Е:61 :00 flashing on screen
www.fewin.com/sony/sony.htm
check out this site for the mavica FD73 solution.
The problem is the lense focus adjustment motor.
Better explained in the above web site.
The sudden impact of the camera frees up the
adjustment mechanisms. Thus the error: E:61:00
disappears. I just fixed my Sony Mavica MVC FD 73.
Jan 06, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
SONY DCR-HC42 - auto focus will not work ???
that problem is on the lens assembly...one the two motor is not working properly...sometimes it is a poor connection to the socket of the main board...other is photo sensor of the lens(not the ccd image sensor)or the driver ic of the 2 motor...i suggest you have to go the service center for repairing you camera cause it need to disassemble the camera for doing this....
Oct 12, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Error message 61:01
thats a lens error, sometimes you can have a loose connection off the lens or fix a bound up focus or zoom motor, otherwise it will need a lens. also check fuse links for the camera power .
Sep 10, 2007 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony DCR-SX40E Camcorder Logo
110 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
