Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Connecting fax line
I have plugged in the power cord but my phone line already has 3 splinters in the jack --do I need extra line for fax to work--also it does not come up on my computer--this is a new unit replacing other one and the tech told me it would be fine as the program was in my computer from other one which is exactly same model--what am I doing wrong???
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Nope..same line should work, in fact, if you have a modem card, you might consider using that as a bridge.
otherwise, it's most likely a configuration issue.
Posted on Aug 19, 2008
SOURCE:
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
Incomplete transmission error report on my mx450
Is this a new problem with a new printer, or did faxes used to work okay until now?
Incomplete transmission means fax could not be sent. Many causes.
1. Error on recipient's end or in phone line (fax machine down, too much line noise, etc.)
2. Bad phone cord or bad phone jack on your end.
3. Make sure the phone cord from the wall is securely plugged into the right telephone port on the printer. There are 2 jacks; the important one is lableled "L" for telephone Line In. The other port (with a telephone symbol next to it) is optional, and is to connect to a telephone (only works if you have a phone line already plugged into :L" port).
4. Other causes: see http://www.fixya.com/support/t8747814-canon_pixma_mx860_stopped_sending_faxes
Dec 02, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I am having problems setting up the phone cords. what all do i need to plug in my fax machine
You should only need the power cord and a phone line. My Brother has 2 jacks for the phone line. One is a line in, (from the wall jack to the fax machine), the other is a line out, (for you to plug in a dial up computer connection or a second phone). Make sure you have the cable from the wall jack plugged into the line in, plug.
Jan 30, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
I need help connecting my fax machine
WARNING
 This machine must be grounded using a three-prong plug.
 Since the machine is grounded through the power outlet, you can protect yourself from
potentially hazardous electrical conditions on the telephone line by keeping the power
to your machine on when you connect it to a telephone line. When you want to move
your machine, protect yourself by disconnecting the telephone line first, and then the
power cord.
 Lightning and power surges can damage this product! We recommend that you use a
quality surge protection device on the AC power line as well as on the telephone line,
or unplug the lines during a lightning storm.
1 Connect the handset.
Connect the curled handset cord to the bottom of the handset and to the left side of the
machine.
2 Connect the power cord.
3 Connect the telephone line.
Connect one end of the telephone line cord to the jack labeled LINE on the left side
of the machine. Connect the other end to a modular wall jack.
Dec 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Change incoming fax number
Unless I'm misunderstanding your question, your fax machine has nothing to do with the incoming fax number. That's assigned by your phone service provider to the telephone line the fax machine is connected to. The only way to change that number would be connect the machine to a different phone line. This might be as simple as just plugging the phone cord into another jack if that line already appears at a convenient location, or it might mean a visit from a technician to place a jack where it's needed. Or you can contact your phone service provider about assigning a new number.
I hope this has helped. If not, please post a comment with more information about your question and I'll try to help further.
Oct 11, 2010 | Canon FAX-L800 Plain Paper Laser
Fax wont' go through. Plugged phone jack into phone line and when I try to fax it doesn't connect. Any suggestions? Thanks
Can you receive any faxes. Run a Fax Test from the Tools menu. Is the problem with only one fax receipient? (Check the phone number and make sure they are set to receive. I have dealt with one fax receipient where the call-waiting service caught the fax call.)
Does the Fax see a dial tone? If there is no dial tone, use a single line phone (corded) to listen for a dial tone at that jack. If there is no dial tone, check the incoming service for a dial tone. (If you have no dial tone at all, contact your service provider.) Try a new phone cable (2-wire RJ-11) Try calling the number from another phone line with the single line phone attached. If the phone doesn't ring with a new cable, check your wiring and then contact your provider. Is the signal analog or digital (the all-in-one is designed for digital)?
Go back through the fax settings and set it as directed in Step 2 here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458259&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3643612 . You need the fax error reporting setting.
Disconnect any items that are plugged into the 2-Ext port.
Try reinitializing the unit. Unplug the power cord with the unit on. Make sure that the phone cord is fully seated in the 1-Line port. Then reconnect the power cord.
Try resetting the all-in-one, this may require 2 people. With the printer on, unplug the power cord and wait at least 20 seconds. Press and hold # and 3 while plugging in the power cord. Release the buttons after the unit starts up.
If none of these steps help the unit may need service.
Jun 27, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Ok Im a ding dong. What plug does the phone line go to. I have 3 holes. One with a pic of a phone, wall jack and the other one is a computer. I need to fax! Help!!
You are NOT a ding dong!
These plugs can be confusing. If you are just going to use the machine to fax, then plug your phone line into the jack on the fax machine that looks like a wall jack and connect the other end to the wall jack on the wall. This is also called the "line" jack.
If you want to use a phone with the fax machine (if it isn't already equipped) then plug the jack in as described above and plug a phone into the jack that looks like a phone. Test for a dial tone.
The remaining jack applies if you want to connect your PC modem through the fax machine. Your PC (assuming you have one) may or may not have a modem.
Dec 09, 2009 | HP OfficeJet D135 All-In-One InkJet...
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
If the supplied phone cord is not long enough, you can extend it. For
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
We have recently purchased a brother mfc-240c, and as far as i no i have installed it correectly yet when trying to use the fax it dails a dead tone and continues to redail but doesnt send, and we...
make sure you have a dial tone by plugging a different phone into the jack. then make sure you have it plugged into the jack on the fax that says line.
Mar 08, 2008 | Uniden Cordless Phone
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
26 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
