Question about Sharp AR-207 Copier
Error code. when the machine is turned on, a "CH" code appears and the machine does not work or warm up.
  • klotzlaw Aug 18, 2008
    I don't have a sorter, but thanks. Seems to have reset itself.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
COUNTER LOCKED ONLY, RESET THE COUNTER LOCKED.
Posted on Nov 09, 2014
  • Sharp Master
  • 2,794 Answers
CH error has to do with your sorter. Check to make sure it is connected properly and see if there is anything jamming inside of it.
Posted on Aug 15, 2008
Ar 5618
The blinking CH means that the Developing cartridge not installed.
Here is how to correct the issue:
1)Turn OFF the power of the machine.
2)Open the front cover.
3)Install the developer unit and toner cartridge.
4)Turn ON the power of the machine with the cover opened.
5)Enter Sim25-02. (Entered value display section: "CH" is displayed. Start LED: OFF)
6)Close the front cover. (Entered value display section: "--" is displayed. Start LED: ON)
7)Press [START] key to execute Sim25-02.When [START] key is pressed, the main motor rotates for 3 minutes to determine the toner sensor reference value and clear the developer rotation time as well as to clear the developer counter.When the operation is completed normally, the ATC sensor reference value is displayed on the entered value display section. If an error occurs, one of the following indicators is lighted. LED Misfeed indicator Paper required indicator This simulation must be executed only immediately after installing developer, Do not execute this simulation for any developer which has been used. If the machine goes into the warm-up state before completion of this simulation, there is a possibility that toner may be supplied to the developer during warm-up. In such a case, therefore, the developer must be replaced with new one.
Jun 14, 2013 | Office Equipment & Supplies
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
* Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control)
Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control)
* While holding the above buttons, plug in the TV.
* The TV will turn on with the "K" or "K123" appears om screen.
* Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
Minolta biz hub 250 ...problem error code c3451
Hi there.
Please try .
Try this.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Jan 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Rca d52w23 convergence problem error code 84
consult the fl231 problem in tips and tricks section
Dec 15, 2008 | RCA P52960 52" Rear Projection Television
New machine
Remove the toner cartridge and reinstall it again. If it appears again turn the power off, wait 30 seconds, and turn the power back on.
Jul 14, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-207 Copier Logo
295 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
