My laptop failed to provide power and cause to fail to start on but the light that indicate the charging process is still on while i have remove the charger
    President:
  • 695 Answers
Try to remove the battery for 5 min ...then get it back
Posted on May 24, 2011
My laptop Inspiron 1501 goes to hibernation automatically after starting up windows. the battery doesn't charge and the battery indicator flashes red. i m using Window Vista Basic. when the icons on...
I believe there is a battery problem which you will resolve when you replace the battery. Have your charger checked or replace it as well.
Thanks for your question @ FixYa.com. Let me know how you make out.
Jul 26, 2011 | Dell InspironTM 1501 Notebook
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
My dell studio laptop fans will run and lights will "blink", then all is quiet, it never finishes powering up and doesn't try to boot up long enough for anything to come on the screen. it is...
the blinking LOCK lights are a no-post indicator. Issues could be:
Bad Ram (Try RAM modules one at a time) A peripheral device causing no -post (Remove all removable items RAM, HDD, Optical Drive, Wireless Cards) see if indications change
If no changes, then most likely a failed motherboard.
Mar 11, 2011 | Dell Studio 17 (1747) transforms your...
Electrical power system service required.....ABS warning light, generator warning light, brake failure...car stalled and wont't restart
usually caused by failed generator. Fix the generator and other lights will also extinguish. The car should jump start, but will not stay running without a charged battery. Recommend removing the generator and take to parts store for testing. Would you like instructions for removing generator?
Oct 17, 2010 | 2001 Volvo V70
My 2001 Ford Focus was low on coolant which caused the multifunction warning light to illuminate. Coolant was added, but now the power supply to the engine is low and the charging system indicator is on. ...
Most "power supply to the engine is low and the charging system indicator is on" is an indication that your Alternator is failing. However it could also be a sign that the Belt is worn, stretched out or is slipping. Check you belt first to determine if you need a new belt.
If the Belt(s) are fine:
One way to determine if the Alternator is bad is start the vehicle and while the engine is running, remove the Negative Cable from the Battery. If the Engine dies, it is a bad alternator, and should be replaced.
The Battery starts the vehicle and run's other nominal operations. The Alternator actually runs the engine,
providing the fire/spark to it. If the Alternator is starting to fail, it will draw power from the Battery.
Let me know if this helped, or if you have any additional information, problems, or questions. Feel free to contact me at FixYa.com!
p.s. When you added the Radiator Fluid, did any spill onto the Belts or onto the Alternator? Radiator Fluid onto the Belt could have caused it to slip, causing these illuminations of the warning lights. It could also kill an alternator pretty quickly.
Jan 27, 2010 | 2001 Ford Focus
Shut Down with message that battery power out. Was connected to AC via power supply at the time
When the ac adapter is plugged in does the charge light come on to indicate the battery is charging? If not, the charger has probably failed. Faulty battteries can also cause a charger to fail. Both need to be checked.
Dec 11, 2009 | Acer Aspire One PC Notebook
Hp nc6220 power trouble
Simply put there can one of several causes. Test the power output at the tip of the charger, weak or failing chargers may not deliver the specified voltage to properly power or charge the laptop sufficiently to continue operation. The DC jack may be worn out and not accepting the proper voltage from the charger. A very hot charger may be an indication of power distribution issues. The biggie may be that the motherboard has failed and is not accepting the signal to keep things running and is ordering a complete unit shutdown before the boot process begins.
Sep 12, 2009 | HP Compaq nc6220 Notebook
Acer laptop will not turn on
Don't think the memory upgrade would cause the power circuit to fault?
It might be your charger - in the transformer circuit block?
Hope this helps.
Oct 31, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
