Are the CS-H305 speakers (Pioneer) 4 Ohm, 8 Ohm or 16 Ohm?
3 Suggested Answers
Gurudristi
  • 98 Answers
SOURCE: 4 ohm speakers with 8 ohm receivers
Please check with the manual of your receiver whether it is capable of running 4 ohm speakers.
if yes, then please go ahead, you will not loose any Sound quality. Sound quality will depend a lot on the performace of the speaker as well as the frequency range it can deliver.
If no, please do not connect. Though, you might be able to play and listen to the music, but it will overload your receiver!!
If you are not sure, please let me know the brand and model of your receiver and I can check for you.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: can I mix 6 and 8 ohm speakers?
Most Yamaha HTR's are high current receivers so setting the receiver to 8 ohms and running the 6 ohm speakers shouldn't be a huge problem. I wouldn't crank the volume though if i were you but at a decent level you should be fine.
Posted on Feb 28, 2010
What is the impedance of the midrange speaker and the tweeter speaker in the Pioneer cs r5100 ? I have the crossovers and the woofers I use for my front channels (L&R)
If you are running three 8 ohm speakers in parallel then the total impedance would be 2.667. If running two 8 ohm and one 6 ohm speaker in parallel you would have 2.4 ohms. This will burn out your amp pretty quick. And very possible won't play at all. Though I have never attempted to play a home amp down that low in ohms. Guessing you may have an older model Denon type amp.
Aug 01, 2014 | Pioneer Audio Players & Recorders
What is the wattage breakdown for each speaker on my pair of Pioneer CS-N575 3 way speaker towers (I know the total max power combined output is 150 Watts)?
It's the woofer that will use almost all from this 150 W so if you replace woofer take one of 8 ohm which can handle 150 W and you done
Jul 15, 2014 | Pioneer Audio Players & Recorders
What size of box in need Pioneer TS-W310D4
if its pioneer shop at walmart lol !!! try a speaker shop or read the manual it has that kind of info in it
Feb 25, 2013 | Pioneer Ts-w309d4 tsw309d4 1400w 12" Dual...
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    Pioneer DEH-P6400MP plus a Jeep Infinity Gold 2 ohm system
    yes but make sure you connect the power wire of the amplifier and buy a converter for the amplifier so you can get great sound.
    Sep 20, 2009 | Pioneer DEH-P4600 CD Player
    Buying an amplifier
    First lets start with how to run your speakers, If you are running all three speakers then you need to wire them in a series so all three of them are a 4ohm load. you can achieve this by taking the first speaker and running the (+) to the amp, then take the (-) and run it to the (+) on the next speaker, then take the (-) and run it to the (+) on the third speaker, then take the remaining (-) and run it to the amp. Now as far as an amp goes you can pretty much pick any amp you want now and not have to worry about overheating since you are running a 4 ohm set-up.
    Aug 11, 2009 | Pioneer TS-W307D4 Car Subwoofer
    Pioneer cs-g404
    My experience with them is that they would work as they don't change much from model to model year. You may call the customer support and they will most likely help you
    try CS @ 800-421-1404 or try the parts hotline to investigate
    (800) 228-7221
    Mar 15, 2009 | Pioneer CS-G204 Speaker
    What are the correct spaekers for the gm 5100t ?
      CEA-2006 Compliant Amplifier Power Standard:
    • 125 Watts x 2 @ 4 ohms <= 1% THD+N
    • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
    • 75 dBA Signal-to-Noise Ratio
    • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
    • 2 Channels
    • Continuous Power @ 4 Ohm: 125W x 2
    • Continuous Power @ 2 Ohm: 190W x 2
    • Continuous Power Bridged @ 4 Ohm: 380W x 1
    • Frequency Response: 10Hz-50kHz
    • THD (1kHz, 4 Ohm): <0.015%
    • Signal to Noise Ratio: >95dB
    • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
    • Oversized Screw-Type Power/Ground Terminals
    • 2 Channel RCA Inputs
    • Speaker Level Input
    • Hi-Volt Input Level Control (200mV-6.5V)
    • Bass Boost (50Hz, 0/6/12dB)
    • Selectable LPF (80Hz, -12dB/Oct.)
    • Pioneer 1-Year Warranty
    I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
    Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
    This is not a pioneer vsx-454 receiver problem
    I would not recomend doing this because the 4 ohm speaker is not enough to offset the 32 ohm speaker and the amp will have problems keeping up with the power consumption of the speakers and will eventully overheat and cause damage! (it will work but not well and not without risk to your amp!)
    Please rate this quick response
    Thank
    You!
    Jun 19, 2008 | Pioneer VSX-454 Receiver
    209 people viewed this question
     Grubhead
    Grubhead
