Question about Dell Latitude D505 Notebook
I have a dell Latitude D505 laptop, and when it power on the following error showing and automatically turned off "The device in the system modular cannot be identified, it may not be completely inserted or may have some other problem.Please read and complete the folowing steps in order." 1.Press the device completely and firmly bay in to yhe bay. 2.Press the ESC key --- wait for the system to powerdown 3.Press the power button to retry detecting the device Please give me a solution
  • 883 Answers
SOURCE: bought second hand c640
Power off even it it takes a battery removal. Now check modular bays and remove then fully insert each device and retry power up. If same results, try repeating above with one of the modular devices removed.
Posted on Sep 09, 2007
Pyrhyc
  • 2028 Answers
SOURCE: it won't boot to the os
The modular bay refers to the optical drive (CD drive). There is a small screw holding it, I've had machines at my shop that this screw fallen out and the drive wasn't making a good connection. Be sure that the drive hasn't slid out a bit. Take it out clean the connection and put it back, making sure it's seated properly. Try this, then let me know, and we'll go from there.
Posted on Jul 29, 2008
crayzeetrayn
  • 837 Answers
SOURCE: When I try to boot
It sounds like either the battery or the drive (floppy or CD-ROM) is not seated correctly. Try removing each of them and inserting them again.
Posted on Dec 22, 2008
drifterK
  • 4924 Answers
SOURCE: either issue with system modular bay or system file removed
remove any cd or floppy disks from the pc...reboot ..if the black screen reaper with the same message about the missing file ..you have to insert the windows instalation cd ...and repair..the missing file
Posted on Apr 08, 2009
  • 206 Answers
SOURCE: Hello Need help I get error below and don't
one of the devices connected to your MB isn't connected properly.
try to remove them and then to install it again
Posted on Nov 14, 2009
Device manager is saying that my PCI modem does not have any drivers installed. I have a Dell Latitude D505 and I can't seem to find the driver for it. I've been on both Dell and Intel's w
Hello Anthony,
The modem that is installed in the Latitude D505 is the
Conexant D480 MDC V.92 Modem, v.MH 2.33, A11
There are only Windows xp and Windows 2000 drivers available. To download the driver you can click the link below.
D505 Latitude Modem Drivers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 04, 2013 | Dell Computers & Internet
Monitor seems to be locked on dell latitude d505
I think its becouse of BIOS logs.
Try following
restart your laptop
press del,f1,f2, f4 any key that applys to enter into bios,
look for the events
clear all event.
hope works.
Mar 14, 2011 | Dell Latitude D505 Notebook
My dell d505 cdrom won't work looked on device manager it says the fault is a code41
The meaning of the above error code is Windows successfully loaded the device driver for this hardware but cannot find the hardware device, pls follow the steps in the below link for code 41.
http://support.microsoft.com/kb/310123 .
Hope this helped.
Jan 21, 2011 | Dell Latitude D505 Notebook
Dell latitude d505 laptop power on & led glows but there is no display, no beed & also the cpu fan is not running , after few seconds thens it turns off automatically. help?
hello
i experience to repair one of those before!!! mostly the problem is in the board you need to bring it in service center for repair.
Thanks
Nov 13, 2010 | Dell Latitude D505 Notebook
How do you reset the latitude d505 to factory settings
How to reset the latitude d505 to factory settings:
If you have Windows XP,
Step 1: Backup everything that is important to you.
Step 2: Boot your computer using the Windows installable CD.
Step 3: Format your harddisk or repartition it.
Step 4: Install Windows XP using the installable CD.
Don't try this if you are not sure of what you are doing. It won't damage your laptop, but you might require a long time to get your laptop working again.
Jun 29, 2010 | Dell Latitude D505 Notebook
When i turn on my dell latitude D505 the backlight
Either the video cable has been damaged or unplugged or the video processor is malfunctioning. Check this by connecting an external monitor. If the video is all there then press the Fn(function) and F4 key. This should switch the video from the external monitor to the internal screen. If this doesn't happen or if the external monitor shows no video then the laptop needs to see a reputable repair perso or check my website www.micromendllc.com
Feb 25, 2010 | Dell Latitude D505 Notebook
My dell D505 turned itself and will not turn back on power light flashes but thats it power supply is fine
  1. Locate Fast IR under Onboard Devices.
NOTE: Ensure that the COM port that you select is different from the COM port assigned to the serial connector.
  1. Press <Enter>.
  2. Use the arrow keys to select the infrared COM port setting.
  3. Press <Enter>.
  4. Follow the instructions on the screen.
After you enable the infrared sensor, you can use it to establish a link to an infrared device. To set up and use an infrared device, see the infrared device documentation and the Windows XP Help and Support Center
http://support.dell.com/support/edocs/systems/latd620/en/UG/setup.htm#wp1112328
Dec 26, 2009 | Dell Latitude D505 Notebook
The sound is off on my D505. How do I get it on
Download the latest drivers for your Dell Latitude D505 off the dell website or try enabling sound in your operating systems control panel.
I said "Operating Systems control panel" because you did not mention what operating system you have.
Oct 27, 2009 | Dell Latitude D505 Notebook
Memory slot location
Its on the bottom of the laptop:
http://support.dell.com/support/edocs/systems/latd505/sm/upgrades.htm#999869
This is the service manual to your laptop and shows you how to change out the memory.
May 25, 2009 | Dell Latitude D505 Notebook
Dell Latitude D505 Notebook Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
