Question about HP Compaq Proliant DL380 G1 Server
There was a tape drive problem , for repair purpose removed tape drive after shutting down the Server and again switch on the server , it's not swithing ON. Just showing a power LED Indicator , SMPS Fan's working but Server FAN also Not Working .
  • 3 Answers
Check all power connection its connected in mother board maybe loose connection remove and re fix it will work
Posted on May 26, 2011
My server poweredge 1800 failed how can i remove data? and the server was configured raid 5
The obvious is to repair it, but if you have another identical server you can place drives and access data. The replacement should boot as failed server. Make sure to track drives and slot location. Shuffling may cause major failure. It may want to stripe itself again and cause data loss and defeating the purpose.
Aug 31, 2012 | Dell PowerEdge 1800 Server
I have a Gateway Server model 9210 Raid 5 (3 drives) Small Bus. Server 2003 and one drive failed. I purchased the same dive. Do i just shut down the server and replace the bad drive or do i hv to go into...
With a RAID 5 setup, if you replace the drive with the exact model, you only need to shut down the server, replace the drive, power on, and the RAID will remount the new drive to the needed confiuration.
Good Luck.
C2Solutions
Jul 11, 2011 | Gateway Computers & Internet
What do i do when tape drive fails to mount and all four lights flash?
Use cleaning tape and clean the drive.
Update firmware of the tape drive via Library and tape tools.
switch off and switch on the drive.
that's it
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
I have a tape stuck in my drive and I can't eject it either on the hardware or using back up exec. The folloing lights are on Green power is on, orange status is on, and red error is flashing Any ideas how...
The only option for you is to remove the tape drive from your server, open it, and manually eject the tape that is stuck. This is not easy to do. Maybe it would be better if you remove the tape drive from the server and take it to a repair centre.
Oct 26, 2009 | Dell Computers & Internet
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Exabyte-220 Tape Library with a 8900 Mammoth drive. Tape cartridge is stuck in the drive - had a power failure during boot of the library. Can press the eject button and hear the tape rewind but the...
These drives are a right pain in the neck!
There is no easy way for an end user to remove the tapes and they are a terrible drive (certainly unless you are using a unix/linux server with all data on this server and not on another networked machine)
My suggestion would be to buy a new drive/library!
Failing that try sending the drive to www.tape-drive-repair.com who should be able to help - but these Mammoth drives are so awful they almost sent exabyte bust so i wouldnt invest too much money in keeping it going. Better to upgrade to an HP LTO4 desktop and cut your losses - Again these guys should be able to help with an upgrade
Jan 19, 2009 | Exabyte 220 MAMMOTH (2700061150) 8mm Tape
Problem with my hp Dat 160 usb backup tape drive
make sure your backup server is not preventing the media being removed
try rebooting your server, if the tape then can be ejected it is probably your backup software.
If the tape wont eject even after both server and drive have been rebooted it is probably faulty and needs to go for warranty exchange with HP
Jul 30, 2008 | HP (C1530B) DAT Tape Drive
StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Sep 18, 2007 | Storagetek L40 DLT Tape Drive
HP Compaq Proliant DL380 G1 Server Logo
77 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
