Question about Aiwa Audio Players & Recorders
Respected Sir, I am having Aiwa NSX-S52 model with serial number 48294. My CD player is not at all working. Neither it is opening or not responding to any of the CD related controls. I am in urgent need of the repair of this 3 CD disk system. Kindly help ASAP. My telephone number is 23042488. Thanking you in advance. Kindly do the needful at the earliest. Thanking You, Abiramy.R
  • 25 Answers
SOURCE: cd player does not work
yes this usually happens when the lens is too dusty, take a soft cloth like a shirt and gently wipe the l;ens that should work if not it is broken
Posted on Mar 04, 2008
SOURCE: No Sound
Tienes que remplazar los IC de audio que esten dañados o enviarlo a un centro de reparaciones.
Posted on Apr 04, 2008
robotek
  • 1512 Answers
SOURCE: cd player multi play problem
Hi dav1892
These units are notorious for getting a layer of dust on the CD optics laser focal lens. You need to give it a clean with a cotton bud moistened with Windex, and then a dry wipe to be sure that there is no smearing left. See how that goes, and get back to me here if it does not fix it.
regards
Graeme
Posted on Apr 14, 2008
  • 3422 Answers
SOURCE: Aiwa Compact Disc Stereo System Model- NSX-51G
HI,
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
Posted on Jun 24, 2008
SOURCE: Aiwa NSX-V70 will not recognize
Hi there. Found your post as I was looking for an answer to the same issue with my NSX v70 about an hour ago. I'm pleased to say that I found a solution on the web and mine is now working fine!
Try this address below and follow the instructions. The knob you need is black, with some white numbers on and can be seen from the back of the unit once you have removed the black casing and the silver back. Quite easy when you know how! Good luck.
http://www.kuro5hin.org/story/2004/3/24/45212/6874
Posted on Aug 06, 2008
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
Accidentally my aiwa 3 cd changer fall down and damaged
Same model is not in stock however new models in Aiwa and Sony are very nice in music.
Jan 25, 2009 | Aiwa NSX-DS55 CD Shelf System
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
AIWA shelf system volume button
I'm sorry but I don't have a listing for that model number. Many of hte Aiwa units use what is called a digital encoder. A call to Sony with the model number should get you the part number as well as the cost and availability. Aiwa is a brand of Sony.
Dan
Dec 15, 2008 | Aiwa NSX-DS55 CD Shelf System
The cd plyer on the aiwa nsx 330 does not recognize cd's.
I can guide you to solve problem in Aiwa NSX-330 but please post problem here as you wrote it in subject area and its incomplete there.
Thank you.
Nov 25, 2008 | Audio Players & Recorders
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
HOME STEREO SYSTEM CD PLAYER
I WOULD LIKE TO KNOW WHY AFTER PAYING WHAT I DID FOR YOUR ENTERTAINMENT CENTER THAT I WOULD HAVE TO PAY FOR THE REPAIR SERVICE PLAN?????? THAT JUST DOESN'T SEEM FAIR AT ALL TO THE CONSUMER. I WOULD LIKE THE EMAIL ADDRESS TO SOMEONE OF SUPVISOR POSITION. THANK YOU
INSTEAD OF CLOSING THE CD LOADER WITH THE OPEN/CLOSE BUTTON SIMPLY CLOSED IT BY CHOOSING THE TRACT NUMBER WANTING TO PLAY. SO FAR IT HAS WORKED. BUT WILL NOT WORK AUTOMATICALLY WILL TRY PROGM. THE REMOTE NEXT SEE IF THERE IS ANY LUCK WITH THAT PART.
THANK YOU
Jul 06, 2008 | Aiwa NSX-A115 Shelf System
107 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
