Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE refrigerator temperature is not cold enough and it's triping water. it's just happen today so what i have to do for that.
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
795.79309.901. Why is water dripping from hole on bottom back right of digital temperature control?
Drain is possibly blocked inside freezer that allows water to escape to the pan below the refrigerator. You will need to remove frozen items and remove the panel that covers the evaporator to get to it.
Leaking Refrigerators
Appliance 911 Sea Breeze
Sep 17, 2015 | Kenmore Refrigerators
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Refrigerator running too much
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
May 30, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
The freezer is not cold enough and won't respond to resetting, does not make ice, does not dispense water
Your unit probably needs re-gassing, unless there is excessive ice build up around the thermostat, which would insulate it. If the compressor is cutting in and out and the temperature is still too high, it could also be the thermostat that is busy failing.
Jun 18, 2011 | General Electric Profile PCF23MGW Side by...
The freezer is not cold enough to freeze nor is the temperature in the whole refrigerator cold.
most likely you have a bad computer board if the freezer is getting warm too.if there's no ice on the back wall of the inside freezer wall then it's the board.you can check this site out
http://fixitnow.com/wp/2009/11/30/ge-refrigerator-motherboard-recall-list/
Feb 01, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Freezer is cold emnough, it's the refrigerator
Hi..
If your refrigerator is not cold enough you need to check this
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!!
Regards
PCmania
Jul 13, 2009 | GE GSH25JFR Side by Side Refrigerator
GE monogram side by side no ice water dispensed not cold
To actuate the ice maker pull the arm down and it is in the on position.
The water is actually cooled in the refrigerator section. However it is not designed for a continuous flow. It takes time for the heat to be removed between each water draw.
If your refrigerator temperature is not cold enough it will affect the water temperature also. Check the refrigerator compartment temperature with a thermometer.
May 16, 2008 | GE PSS26MGS Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
