Question about Canon Laserbase MF6530 All-In-One Printer
I am getting a "toner empty" message yet the cartridge is full
Can anyone tell me what to look for on the cartridge
    Champion:
  • 214 Answers
Hi, most of the printers show this message after the catridge change. not a problem if you can print properly.
thanks
Posted on Aug 15, 2008
REPLACED THE TONER CARTRIDGE WITH A REFILLED ON AND GET THE ERROR MESSAGE "SYSTEM ERROR F2-70"
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Mar 17, 2015 | Sharp FO-2081 Copier
Dear Sir, I full toner cartridge but again and
if u FILLED tone cartridge, then u probably need to replace the little ckt bd on the cartridge that is responsible for telling u it is empty.
if u REPLACED the cartridge, then it may not be installed properly or there is another issue.
Oct 20, 2013 | Office Equipment & Supplies
Hello. I am getting a message that my yellow toner cartridge is empty and the printer (Konica Minolta 2300W)refuses to print out anything, even though I got it into the B/W mode. The complete message...
It won't print anything if one cartridge is empty, even black when the colour is empty. Are you using new or refilled cartridges? The cartridge has a chip on top that counts your number of prints, so it could feel full, but has reached it's end counter. Try another cartridge. That should solve your problem
Aug 06, 2010 | Konica Minolta magicolor 5430 DL Laser...
My toner was low, so I replaced it...it printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Thanks,
Pat
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Toner level
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Jun 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
RESET TONER C9100
The waste toner cartridge has a transparent extrusion on the bottom, which fills with toner when the cartridge is full, but also if it is half full and shaken so that toner falls into this extrusion. If this happens, the only way to remove the toner is to open the cartridge by removing the tape, taking the two halves apart and shaking/blowing/hoovering it empty. You can stick them together again with ordinary sellotape.
Jun 17, 2009 | Epson Aculaser C1100 Printer
Hi, My Dell 3100CN printer is displaying "Change Black Toner." I have replaced the toner cartridge. The printer begins to calibrate for a very long time. When it finally finished calibrating, it return to...
There is a chip in each toner cartridge which tells the main machine something about how full it is. It may be that it tells it how full it is, or it may be that it tells it how many pages it has done. It sounds as if the new black cartridge has a duff chip, and is telling the main machine that it is empty. To test this, you can overide the message. 1. press on the menu button;
2. select configure;
3. select maintenance;
4. select non-dell toner;
5. set the value to on.
If that does't work, get back to me.
Tony Ludlow
Feb 22, 2009 | Dell 3100cn Laser Printer
False Toner message
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Jun 21, 2007 | HP LaserJet 4600dn Color Printer
Canon Laserbase MF6530 All-In-One Printer Logo
old marine
old marine
