Question about Frigidaire GLER642A Electric Dryer
The dryer's motor, blower assembly vibrates, makes a lot of noise. what could be wrong?
catriver
  • 878 Answers
SOURCE: blower wheel on dryer is loose
Jclay, you are in for a little work here partner. On this model the blower is up-front. The dryer is going to have to come apart for you to tighten or replace the blower wheel. The end caps on the consol will pull off. Remove the two screws on each end securing the consol. Flip the consol up. There will be 3 quarter inch screws under the consol, in back, holding the top on. Remove these and the top will slide off, forward. Remove the bottom panel by the blower. Remove the lint filter. Remove the 4 screws attaching the front panel and door to the front of the dryer, remember to unplug the door switch cable. The drum now can be removed after removing the belt. Take the tension off the belt by moving the pulley over. Remember the belt configuration so you can put it back on right. Once the drum is removed you will now be able to get a wrench on the motor shaft itself so you can tighten or replace the wheel. Reverse the above steps and your back in business. Im going to attach a picture of a rear blower system and the way to take it off. Yours is up front but the removal will work the same way. Sometimes you have to cut the old blower wheel off because it's fused on with heat. Your part number for the wheel is 697772. Remember to unplug the dryer during this work..Catriver..post back.
Posted on Aug 30, 2006
  • 686 Answers
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
heatman101
  • 43501 Answers
SOURCE: the dryer is making a loud noise-like metal on metal
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Apr 18, 2010
  • 116 Answers
SOURCE: remove blower blade from motor
A guy who has been repairing these for twenty+ years told me sometimes the blower fan is just too tight to remove. If so, you have to use a screwdriver or punch from the motor side and literally break the plastic fan apart. I thought that was going to be my problem, but..... With wrench tightly fastened to the nut at the back of the motor and resting against the post of the rubber wheel, I put a sturdy wrench on the shaft at the front of the motor and whacked it in a clockwise direction with a hammer. It snapped and came loose! Hooray. Try that before you demolish the blower fan.
Posted on Jul 30, 2010
SOURCE: our dryer is making a
If it is hot and humid when you run the dryer, then the exhaust tube has come loose from the back of the dryer, or you have a hole in the vent hose. Basically what is happening is the moist air that is supposed to travel outside is backing up into your house. No cause for alarm right now since the steam is harmless, But over time, the hummidity might cause a mold problem if it not addressed. I'm looking for answers on loud dryers so I cant answer your second part, but I'll bet its a belt issue.
Posted on Sep 30, 2010
Turning the heat on makes lot of noise
If the blower motor is noisy, the bearing may be getting bad inside the blower. This will require replacement of the blower motor unit. In some cases, foreign objects can fall into the motor casing assembly also making a noise. The motor will need to be removed for inspection
Jan 14, 2016 | 2007 Nissan Sentra 2.0 SL Sedan
Frigidaire electric dryer front load . Bad vibration
Good Afternoon David,
I understand you are receiving a bad motor vibration on your Frigidaire dryer. I see that you replaced the fins on the blower, only to have them break again. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing the vibration noise, as well as the blower fins to break. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Electric Dryer
Maytag Legacy series dryer making loud noise. Sounds like something flapping.
A common problem on these dryers is the blower wheel itself will wobble out and make noises. Pop the top with a putty knife then remove the front panel. Check the blower housing for looseness.or something in it. I worked on a monkey wards dryer with a bad blower wheel and made crappy movie on my phone:
Sep 04, 2012 | Maytag Dryers
2005 Toyota Corolla. Bought it from a guy that lives in the country. Took apart ac cabin filter today and found LOTS of mouse or rat stuff. Vac a bunch out and got a new filter...now ac is making a loud...
removal of the blower motor is quite easy. you can access it from the passenger foot area. remove the glove box by removing the limit rod screw and squeezing the sides of the glove box together to remove. You can now better visualize the area. remove a few plastic clips that hold an electronics shelf and move it aside. remove the electrical connection to the blower ( take note of orientation of plug so that you put the motor back in the correct position) remove three screws that hold the blower in place. Pull blower assembly down. clean or replace blower. Rockauto.com sells a complete blower and fan assembly for very little $.
Aug 15, 2010 | 2005 Toyota Corolla
When I turn the start knob on my Frigidaire Gallery Model GLER341A52 the motor makes a humming noise but nothing else, when I let the knob go it stops. The drum never turns or blower doesnt start it sounds...
Wow, different person, different dryer, same problem, same day. I went and got a complete new motor assembly for $170. I hooked it up, and it is still doing the same thing. So obviously that is not the answer. What did you find?
Nov 19, 2009 | Frigidaire GLER341A Electric Dryer
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Sep 01, 2009 | Amana Dryers
When I turn on my dryer on it gives a rattling/vibrating noise.
There maybe a lot of lont build up in the blower wheel housing. Take off bottom panel and take apart the blower wheel house and check for any lint build up....if it check ok, your drum rollers maybe worn....try checkin the blower wheel housing...hope this helps
Aug 04, 2009 | LG DLE2516 Electric Dryer
Dryer vibrates with exhaust hose attached
Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
May 21, 2009 | GE Profile Harmony DPGT750EC Electric...
York P3HU Gas furnace blower making grinding noise and vibration
If the wheel is rubbing on the housing obviously that's no good. Yes that is one solid piece, it needs replaced. Not an extremely difficult job, toughest part likely getting the wheel off the shaft. Sand exposed shaft and use some lubricant. Before removing motor mark on the housing where the wires are located/ direction they point. Do not forget to tighten set screw upon reassembly. Good Luck!!
Mar 28, 2017 | Heating & Cooling
York P3HU Gas Furnace Blower wheel makes noise and vibrates
yes you have a bad blower wheel the fins are crimped to the disks, if you can take the blower assembly out just watch the wiring and take the motor out of the center of housing away from blower wheel and when taking out the wheel remember the diriction of the wheel
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Frigidaire GLER642A Electric Dryer Logo
52 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
