Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV KV-X2973E uk model: no sound in SCART or AV1, AV2.
Hello!
I have this sony crt TV model KV-X2973E whitch first, had sync and sound problems (picture sliding horizontaly and sound going loud out of control after some 20 or 30 mins of warming up.). I changed IC 304 and, to make sure IC 201 (CXA-1855s and TDA6612). After that all seemed OK, but after some 10 mins or so, sound faded and went silent. Searching on the net I found the cure were it was said to change R627 (on audio PS board). Now everything is OK but when I connect the VCR or Satellite or AV camcorder there is no sound. I haven´t either audio out on the scart from the external sources. I checked the power suplies. +22V -22V +9V all seem ok. No blinks on the LED´s. I have no ideia where to search to cure this problem. I hope someone will kindly suggest a psssible solution. Thanks in advance for your help. Answers to: arturduque@hotmail.com
Ple
  • ticotur Aug 16, 2008
    Yes, I downloaded the diagrams.
    I´m a retired electronics service engineer, (Scientific and medical equipement). but no oscilloscope. Thanks for your help
    Ticotur
    Hi Welcomegee!
    Thanks for your fast and kind help. I got the manual fromhttp://www.free-service-manuals.com.
    Set is around 11 years old and wish to give it away.
    I´m following your suggestion through the mute circuit. In TV reception the mute and sound are working perfect.
    I guess I have to get a scope and trace the audio external source.
    Thanks
    Ticotur
  • 10,594 Answers
Do you have its schematics or service manual? This kind of problem needs detailed schematic diagrams of related product. Let me know, are you Tech-Person or TV-Repairman?
Posted on Aug 15, 2008
  • Shahid Electronics
    Shahid Electronics Aug 16, 2008
    Thanks for response and nice to know you as engineer. Though I don't have info for UK models in my PC yet I would try some tips or hints.
    There would be Audio Mute command comes from System Control IC, please locate it in schematics and temporally disable it by some sort of open circuit ( remove resistor ).
    If your TV is around 5-6 years old, then it has IF Module near RF Tuner. check this IF Box as its responsible for demodulated audio.
    Your might has defective Source Selector IC i.e RF / A-V1 / A-V2 selection.
    Hope these info would help you.
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
Can't find AV1 on menu
You can Convert the DVD to Video OR Convert DVD to Flash,play on PC.
http://www.powerpoint-video-converter.com/
Nov 20, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Trying to hook up a PS3 to a regular older TV (Zeneth). What do we need to make this work
hello just the black lead that has 3 coloured jack plugs on the end and scart block. on the tv at the back there might be 3 scart sockets av1 av2 av3 or e1 i'd connect it to av3 good luck
regards
shaun
Jul 17, 2010 | Sony Playstation 3 (PS3) Console
Srt 2219b im try to setup to watch dvd and vcr. is there a trick.
If you are connecting your DVD and VCR to the TV using Scart leads, simply go into TV input option on your tv remote and switch to AV1 or AV2. i.e AV1 for VCR or AV2 for DVD player.
Mar 17, 2010 | Sylvania SRT2232S 32" TV
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
Nov 29, 2009 | Panasonic CT-32SL14 32" TV
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
My sony vega tv switches av settings
Will you specify Model number of Sony Wega TV to understand its circuitary.
May 31, 2008 | Televison & Video
Digibox connection
Try looking on the links from a thread on connecting a PVR on bbc.co.uk's POV digital pages
Sep 17, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
317 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
