Question about Haier HVTS18DABB Wine Cooler
I have a HVTS18DABB wine cooler and the top fan stopped working. I replaced the fan and it still doesnt work. The control panel lights up when plugged in but for some reason the top fan still wont work. Please help.
  • pnorwood1 May 24, 2011
    how do I do any of the above mentioned items? i.e. testing the realy
    How do I test the relay?. do I need a special tool? Should the refridgerator be plugged in?
  • Haier Master
  • 11,800 Answers
The fan is powered thru a relay on the control board. If the fan is new and in working order then either the relay has failed or the wiring connecting it to the board are broken.
You will have to open the top panel to access the control board and measure the output of the relay - if the relay works then the wires are faulty. If the relay doesn't then you must measure its input/command signal - if it's there then the relay is faulty, if it's not then the fault is in the control board, more testing will be needed.
In the worst case scenario the entire control board will have to be replaced.
Posted on May 24, 2011
  • Azrael SRL May 24, 2011
    No special tool, just a simple voltmeter/multimeter will do. You identify the plots on the relay - 2 for the output/fan, 2 for the input/command - and you measure the voltage across them. Yes, of course it has to be plugged in.
MODEL #HAW18ABB
www.haier.com/us/servicesupport/overview
Jun 11, 2014 | Haier HVTS18DABB Wine Cooler
The top fan is not working and is heating up top compartment. The fan seems to be stuck.
remove the back metal panel and unscrew the top fan and unplug the terminal the cable plugged into the board. I spread disc brake cleaner and then wd-40 into the coil area with a fan spins. manually spin the fan with your finger a few times to get the lubricant evenly distributed. I had the same with my top fan and if the same
Mar 17, 2013 | Haier HVTS18DABB Wine Cooler
I need to know where the board RF-5210-56 is located on the wine cooler model hvts18DABB
Number 19 in this photo is the control boards location=> HVTS18DABB Parts Breakdown
and if you need the user manual click here=> HVTS18DABB User Manual Please rate this if helpful and should you have more questions please ask, Thanks Sea Breeze
May 09, 2011 | Haier HVF042 Wine Cooler
Top fan is not working
The HVTS18DABB wine chiller is truely a piece of **** when it comes to their fans. I have had top fans in the top chiller fail. Solution: Don't buy the replacement part as it will only fail again. Instead, go to your local computer parts store and purchase a high quality 120mm computer fan with a good motor and bearings. On the old fan, snip the wire harness as close as possible to the fan body. On the new fan, remove the connectors that come on the fan. Attach the red wires and the black wire and wrap each with electrical tape. Trim back the yellow wire and tape the end, isn't needed. Remount the fan and you are good to go. i plan on replacing the bottom fan soon with a quality PC fan as well.
Feb 19, 2011 | Haier HVTS18DABB Wine Cooler
I have a Haier HVST18DABB wine cooler, and the upper fan has stopped working (appears to have seized up). What are my options for replacing the fan? I have removed it from the unit, and it is marked...
Hi Bill,
Not sure if you got an answer to this question or not, but I had the same issue and thought I'd reply just in case you still needed help. I was able to order this part for about $30 (including shipping and tax) from http://www.partstore.com. The item number for the top fan is RF-2750-44 and the number for the bottom fan is RF-2750-45.
Based on other posts on this site and other sites it seems that the upper fan dies on this particular model quite a bit.
Andrew
Jan 22, 2011 | Haier HVTS18DABB Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
NEED FAN FOR MODEL HVTS18DABB
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be affective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Jul 18, 2009 | Haier BC112G Wine Cooler
Haier HVTS18DABB Wine Cooler Logo
132 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
