Question about Toshiba Regza 46RV535U 46 in. LCD HDTV
Good Evening, I was programing the stations and accidentally turned the power off while TV was still programing. When I turned the power back on there is no picture. The power light comes on but no picture.
  • Toshiba Master
  • 8,457 Answers
Redo the tv programming for tv channels again.Will be reprogramming the tv stantions again,all the tv station channels will come back again.
Posted on May 24, 2011
The child lock is on my tv hitachi older model. i have no remote and the tv is turned off.. how do i get it back on to remove the lock???
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time.
Instructions
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Oct 03, 2012 | Televison & Video
Parental code not working on sansui television
Instructions
Jun 27, 2012 | Sansui Televison & Video
Hitachi 51F520 keeps turning off and on
hi, the tv is not set on sleep timer is it. the other fault could be a dry joint or a swollen capacitor a loose board with the power off you will need to do a visual check make sure you've got a good light hope it helps
regards
shaun
Dec 06, 2011 | Hitachi 51F510 51" Rear Projection...
I have a sanyo Ds27820 tv. power button is gone and now remote is broken. tv was accidentally shut off...how can I turn it back on? Thanks
there are two ways: 1.- to buy an universal remote control (this is more easy) or 2.- replace the power microswitch and rebuilt the button.
Mar 17, 2010 | Sanyo DS27820 27" TV
Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
May 18, 2009 | Philips TP2784C TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Good evening, I am trying to connect my LC-32G2x to my PC. I had already connect the soun without problem but I cannot see the image of the PC signal on the sharp LCD. Please would you advice what might...
DIsconnect your PC from the TV and Shut it Down. Then turn off the TV and reconnect them back and switch on. If this fails to be of Help, contact Service Station.
Aug 04, 2008 | Sharp Televison & Video
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Presting the stations
Either your radio has some issues (which is possible), or your memory wire (the yellow one) is not connected properly. You need to make sure that the yellow wire has power 24/7 and the red only with the key on. That said, there are some cadilacs that dont retain that constant power for more than 10 or 15 min after the car is turned off. If you have a caddy. hit me back and I'll tell you where to pull power from.
Good luck
Dec 02, 2007 | Panasonic CQ-DP383U CD Player
Toshiba Regza 46RV535U 46 in. LCD HDTV Logo
169 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
