Question about Samsung HP-R5072 50 in. Plasma HDTV
Red dots i have a 50 inch that has red dots in the black what do i do
  • Anonymous Nov 07, 2008
    I have the same problem. My tv is one month old and it has a bright red dot that is visible on a black background. I was offered a screen replacement under warranty. Shoul I go with that offer? I am not sure if it will be all working the way it should when they put it back together. Please, anone that had it done share your oppinions
We had same problem with our Samsung last year. When my husband called, they knew immediately with the problem was and sent someone out to replace the main board. If we hadn't been under warrantly, it would have cost a fortune.
Posted on Sep 06, 2008
2 Suggested Answers
SOURCE:
smarthome2
  • 1114 Answers
SOURCE: I have a Panasonic palsma
Sounds like it's in service mode. Unplug the set and leave it for 10 min or so then plug it back in. If you still have the problem, post a comment with the model #. I'll pull the manual and take a look for you. Hope this helps
Posted on Jan 16, 2011
Red/green/blue static toward top of screen
Very likely either the YSUS board is going bad and/or the power supply voltages are getting noisy because of failing capacitors.
Dec 02, 2013 | LG 50PX1D 50 in. Plasma Television
I have a Panasonic palsma 50 inch TV and it is all black screen with a big red X and two dots under it. What is the deal?
Jan 16, 2011 | Panasonic Televison & Video
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
HP-R5072 50 in. HDTV Plasma Television: i have one red dot on plasma screen. it is always ...
Unless you see more red dots, this kind of "defect" is under specifications for this size of PDP, if you do not like it, the PDP module must be changed
May 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Mar 29, 2008 | Car Audio & Video
Red, purple and green dot
Its the light engine. Had a tehnician come and look at mine and was told it would have cost over $600 if I didnt have the warranty. Panasonic called 2 weeks later and told me that parts are no longer available for my model and are upgrading me to a 50 inch tv.(from 44 inch)
Nov 29, 2007 | Panasonic PT-52LCX65 44" HDTV
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
496 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
