Question about Refrigerators
Haire hvt18dfbb cant find any documentation on the product free online so here it goes, basically 1. rear cover off 2. dust free 3. light, fans inside and out running 4. seals intact 5. upper compartment is now cooling to desired temp 6. upper heat sink and fans getting warm 7. lower compartment is where the trouble is 8. lower wont cool at all and heat sink is cool 9. board seems to be good 10. underneath the circuit board is okay 11. what can i do now to save this what i would call a nice wine cooler? ps i will not have it sent out, and i own soldering equipment. hint. djdanielsunllc@gmail.com
  • 5 more comments
  • rpaulmeyer Aug 26, 2008
    Lights and fans run on my HVT18DFBB Aficionado but does not cool either the top or bottom...at a loss as to what to do !!
  • Anonymous Sep 08, 2008
    Similar to above, top zone does not cool while bottom zone still does.
  • zbonefas Dec 29, 2008
    I have the same problem. The top gets cold, but the bottom doesn't. I have the unit torn apart, but there is no obvious defect.
  • jdeloach Jan 30, 2009
    I have the exact same problem! How can I fix it???
  • mikelsmith Feb 05, 2009
    I had the same problem... top was cool but the bottom was not. I unplugged the unit for awhile and now when I plug it in I have no power. When I unplug there is a faint clicking sound for a second or two. When it is plugged in there is nothing, no lights, no fans, nothing. Anyone ever had any luck replacing parts??
  • Anonymous Feb 18, 2009
    Top doesn't cook bottom does.
  • Anonymous Mar 30, 2014
    The upper compartment of my Model PFWC18 is not cooling. If fact it appears to be heating. Set to 45F goes to 71F. Fans on both sides if the heat sink run constantly.
If either the top or bottom compartment is not cooling, then the thermal couple (cooling module) behing the fan and heat sink is bad. It can be replaced with part number RF 4545-14 but they cost $70 each. One on the top and another on the bottom. You would need to solder a few wires. I think, this is not worth the cost, since the fridge cost about $150. Also if you don't get power than the circuit board in the back has burned-out. The replacement for this part is RF-5210-37 cost about $38. I replaced the the circuit board after the fridge wouldn't go on. Now the top compartment won't cool and I need a thermal couple. Total cost would have been $130 and I think it's not worth it. So since I fixed the power issue, I will use this fridge just for my reds in the bottom compartment for as long as it will last. I will remove the broken thermal couple, maybe I can put together my own.
Posted on Apr 03, 2009
  • keithmcmahan Aug 26, 2010
    Inside the RF 4545-14 is a TEC1-12706 thermal electric device that can be purchased a lot cheaper than $70. ( Found on EBay for about $3) It doesnt take much to replace it. Just add thermal grease.
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
I do not have a tool to open fan so i can clean the dust out
Hi, a can of compressed air is what you need, can pick them up at most hardware shops, can be purchased online also-http://www.ebay.co.uk/itm/2-x-Compressed-Air-Duster-Spray-Can-200ml-Cleans-Protects-Laptops-Keyboards-/370750150980?pt=UK_Computing_Sound_Vision_Cleaning_Equipment_Kits&hash=item56526e5944
A few blasts should loosen any debris, then simply run the fan to remove any remaining dust.
Apr 12, 2013 | Lasko 2535 Stand (Pedestal) Fan
Aficionado hvt18dfbb is running but NO TEMP CHANGE
There is no compressor on these units. These units use a Peltier cold/hot module where the cold side faces the heat sink and the fan exhausts the heat side. Another fan sends the cool side into the frig. I have the same unit, I am experiencing the same issue. I was looking to change out the Peltier modules (about $7 each) and try that. I did find a replacement Control Board is about $45 and if the Peltier change doesn't work this may be my next step.
Nov 08, 2012 | Haier HVA052ALL-8S 52 Bottle Aficionado...
Green power light doesn't turn on but the yellow light goes on
In your added problem along with more information now, you have witnessed what I have previously stated;
http://www.fixya.com/support/t11034057-compaq_presario_sr5110nx_will_not_start
Bad Power Supply.
Weak voltage power rail.
Not enough power to turn the Processor on.
1) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical processor can use from 51 to 125 Watts of power. Just depends on what Processor it is.
(CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short )
The Processor in a Compaq Presario SR5110NX Desktop PC is an
HP Support > Compaq Presario SR5110NX Desktop PC > Product information > Product specifications > Compaq Presario SR5110NX Desktop PC Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01050244&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3436819
Processor - (AMD) Athlon 64 3500+
Socket 939 processor socket,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22ClawHammer.22_.28C0_.26_CG.2C_130_nm.29
Depending on what Core it is based on, (ClawHammer, Newcastle, Winchester, Venice, Manchester, etc), it can use up to 67 Watts, or 89 Watts.
No Processor operating, No computer.
Replace the Power Supply.
{ Also clean out the inside of the computer with a can of compressed air for computers, on a regular basis as needed. It may be every two weeks, if the situation calls for it.
Remember to follow Anti-Static Precautions, BEFORE reaching inside the computer.
N-E-V-E-R use a vacuum cleaner to clean a computer.
A vacuum cleaner produces Static electricity.
{Hold the plastic wand device sideways, over your hair with the vacuum turned on. Your hair will stand up from the Static.
Have seen many a so-called computer tech fry a unit using a vacuum }
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 25, 2011 | Compaq Computers & Internet
HP Officejet Pro 8500 has problem with document feeder. I can reset it by turning the gear on the inside rear of the ADF door. I lift the door and spin the gear and the pull roller will drop down. Other...
Follow this steps to make it work..
SOLUTION #1 CLEAN THE ADF FEEDER 1. take out all the papers that you have on the printer 2. turn off (c01602202.gif) the printer using the power button 3. unplug/disconnect the power cable at the back of the printer 4. Lift the cover of the ADF, and then find the rollers and the separator pad.
what is separator pad?? click here
5. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth. 6. Use the damp cloth to wipe any residue off of the rollers and the separator pad. 7. Dry the rollers and separator pad with a dry, clean, lint-free cloth. 8. Close the cover of the ADF. 9. Reconnect the power cord to the rear of the product. 10. Press the Power button (c01602202.gif ) to turn on the product. 11. Reload the original document print side up in the document feeder tray. 12. Try to make a to make a copy again using the ADF, if you are still having issues with it, continue to the next step.
SOLUTION #2 RESET THE PRINTER 1. turn off the printer (c01602202.gif) 2. unplug/disconnect the power cable at the back of the printer 3. while the printer is off and unplug, on the control panel of the printer press the # and number 3 at same time (keep on pressing and wait for 1min) 4. after 1min. keep on pressing the two buttons then plug the power cable back in to the printer. 5. If the printer does not turn on, press the Power button (c01602202.gif ) to turn it on. 6. release the buttons when part NVM reset appears on the printer screen. 7. press ok, then continue the following task.
IF THIS STEPS DID NOT RESOLVED THE PROBLEM CONTACT HP PRINTERS SUPPORT DEPARTMENT 1-800-474-6836
Good luck! :)
Jan 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I had a paper jam and I took the back off and this
Step one: Remove any loose paper
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
E50a10 blinks four times
Four blinks is a fan rotation error code which means one of the four fans is not operating properly. Check these fans and replace any found defective.
  • Remove the lamp cover.
  • Remove the rear cover by removing the 13 screws holding it in place.
  • Check the fans.
053bd7d.jpgLocation of fans 1 and 2
Location of fans 3 and 4
Dec 07, 2009 | Televison & Video
Modem light is blinking no internet light
hi, there are two ways to assit you on this issue.Either you can call belkin customer care which is a TOLL FREE no. on the product box and get assisted or else proceed with the following basic steps.
1. the product that you have is an obsolette.
2.Before troubleshooting the belkin product. Please connect your computer directly with the modem (without router)on the ethernet(lan) port and check for the solid lights on the modem after turning it on, after that check for internet connectivity, if you can go online, its fine else you need to contact your modem vendor and get fixed.
3. if u can go online, then connect your router isolated port to the modem amd your computer back to the router's lan port(port 1) and check for the solid internet,power,modem,lan lights on the router.
4. if all are solid lights , check you can go online else you can hold the reset button at the rear side of your router for 2 mins if you have a cable modem and then check for connectivity.
5. If you have a dsl connection , then better contact customer care, they assit you very well.
Sep 21, 2009 | Belkin (F5D6230-3) Wireless Router
Loacation and replacing dust @ pollen filter, 2000 vw beetle
Dust and pollen filter, removing and installing
The filter is located in the right rear of the instrument panel under a cover.
Components of dust and pollen filter:
97527421
1 - Frame 3 - Filter element 4 - Plastic nut, 2.5 Nm (20 in lb ) 5 - Filter housing with seal Removing
97527422
  • Push center cover -1- forward -arrow A- and lift up to remove.
97527423
  • Remove screws -arrows-.
  • Lift right plenum panel cover -1- and remove from clips at front and rear edge.
  • Pull cover -1- toward center of vehicle and out of retainer in A-pillar to remove.
97527424
  • Remove screws -arrows- and remove right closeout panel -1-.
97527425
  • Remove rubber grommet -1-.
  • Press tabs of filter housing in direction of -arrow-.
  • Remove filter element with frame in upward direction -arrow A-.
Installing
  • Guide frame -1- into first slot on left and right sides of new filter element.
  • Press frame with filter into housing -2- and engage retainers.
Jun 05, 2009 | 1999 Volkswagen Beetle
Acer aspire 5100 series
it sounds like it over heating. on the bottom remove the big square cover on the top right corner there is a fan remove the 2 screws on the top and remove the fan now remove any hair and dust with can air. emal me with any ?'s ag2barker@yahoo.com
Jun 25, 2008 | Acer Aspire 5100-5022 Notebook
Refrigerators Logo
1,163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
