Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Hp officejet pro 8500 cleans printhead everytime i turn it on. and it uses ink! how cani deactivate it? how can i set to cleaning it manually?
  • HP Master
  • 817 Answers
That is quite normal . All inkjets run a cleaning cycle when turned on to make sure there is a good flow through the printhead and to prevent the head from becoming blocked. You cannot turn it off.
Posted on May 24, 2011
  • 1 more comment
  • stevenmuylae May 28, 2011
    I have the same problem, but even worse : he cleans his printheads every 2 to 6 printed pages !!! It has become absolutely impossible to keep on working with this printer ! There must be something wrong ! Who can help ?
  • bldrman77 Aug 07, 2011
    This has got to be the dumbest "innovation" that HP has ever devised! Our 8500 decides to "clean the printheads" right in the middle of "time sensitive printing" when important clients cannot stand around and wait for a cleaning process to be over. Let me manually decide when to do this procedure and I'll gladly assume the resulting risk, as I have done in the past with all my previous HP printers. If this cannot be resolved, my loyalty to HP is over!
    Steven........it's been 2 months since you posted. Any luck in resolving this issue?
Hp officejet pro blank pages with full ink cartridges.
Try reinstalling all of the printer software. If that does not do it then something is wrong with the printhead itself, specifically the area that controls the flow and metering of the black ink.
Aug 03, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
I have a continious inking system and ink streak. we took it apart and cleaned the ink ports and the ink runs through the tubing firn
Hi
This is not the problem with the ink supply through the tubing. But your printheads need to be cleaned hence using the HP software which is installed in your system try to clean it and it will solve much of the problem you are facing if not then you have to replace the heads.
Regards
Jul 24, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My HP Officejet 8500 pro Wireless does not align. I have just put original HP cartridges. It shows a fail message and asks to refer to documentation
This is a mechanical problem... you need to refresh the settings on the printer.
Follow this steps to make your printer working
*Clean all the toners manually. (make sure that the printer is on) -get a clean wet cloth/ cotton swab. -take out all the ink cartridges in the printer. -use the wet cloth/cotton swab to clean the electrical contacts on the ink cartridge it self. -when your done cleaning all of them, put them in a warm area and make sure that it will not leak. -go back to your printer then, take out the printhead (the one that holds the inks) then you need to clean the electrical contacts as well.
after you cleaning those toners put them all back to the printer. click here to view the video clip on how to put back the printhead. click here to view the video clip on how to put back the inks. close the cover. (the cartridge access door) when your done doing it, proceed to the next step.
*Power cycle the printer -turn off the printer. -unplug the power cable at the back of the printer. -wait for 1min. -plug the power cable back in. -turn on the printer
*Clean the toners using the control pannel of the printer -press the Setup (wrench icon) button -keep on pressing the right arrow key then, look for the "tools menu" -under tools menu look for "clean printhead" -after your done cleaning it and its ask for level 2 cleaning process, please do so. -after cleaning press the setup again, look for tools, then look for align printer. -after aligning it, you should be getting the message "Alignment Successful"
Note: If your still getting the message "alignment failed" contact HP printers support department 1-800-474-6836.
Congrats in advance! :)
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
It's hard to believe this story is true, but I assure you it is all true. 1- In October 2009 we purchased an HP Officejet Pro 8500. Not long after installing it we got constant messages "Printer is...
1 you said the cartridge is low.
it happens because the ink cartridge must have been used for initializing the printer which does take a lot of ink. please purchase a new cartridge and the issue will be resolved.
2 Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.
NOTE: If error messages also display on the computer, clear the error messages after each of the following steps. You might have to delete pending print jobs from the print queue on the computer to clear the error messages. Solution : Clean the electrical contacts Follow these steps to clean the electrical contacts on the printhead and inside the product. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components. Step one: Clean the contacts on the printhead Follow these steps to clean the contacts on the printhead. NOTE: The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button. CAUTION: Proceed only if the carriage is on the left side of the product. If it is not, the printheads will be damaged when you install them. If the carriage does not move over, try turning the product off and on again
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet. NOTE: Do not turn the product off by pressing the Power button (c01602202.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01817489.jpg
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle to remove the printheadc02548320.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead. CAUTION: Wipe only the electrical contacts. Wiping the ink nozzles, located on the underside of the printhead, can damage the printhead. Do not touch the nozzles. Doing so permanently damages the ink nozzles, and the ink stains clothing. Figure 3: Electrical contacts and ink nozzles c01817491.jpg 1 - Electrical contacts 2 - Ink nozzles
  9. Wipe the electrical contacts with the swab until no ink residue remains.
  10. Wipe the electrical contacts with a fresh cloth to dry them and remove lint.
  11. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
Step two: Clean the contacts inside the product Follow these steps to clean the contacts inside the product.
  1. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01817492.jpg
  2. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
Dec 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I clean the printhead or do I need to clean the printhead
Only clean the print head when you are have ink issues. And you do so with a cotton swab and alcohol on the gold etchings on the print head only.
Nov 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Owners Mannel For Inkjet 8500
Go to the following link:
www.fixya.com/support/p378934-hp_color_laserjet_8500_printer/manual-34213
Nov 22, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
817 people viewed this question
Seeker5211
Seeker5211
