Question about AMD (axmd2400fjq4c) Athlon XP 2400+, 1.8 GHz Processor
I have an AMD athlon processor. I want to set my screen resolution to 1920 x 1080 (Full HD). But in Properties --> Settings, this option is not there. My monitor's native resolution is 1920 x 1080. How can I set the screen resolution to Full HD? Please help.
    Scholar:
  • 157 Answers
Sir,
which O.S. u r using? XP/Win7? do the below mentioned steps.
For Win7- Place the cursor on desktop rightclick-Personalize-Click on DISPLAY(Bottom left side)-ADJUST RESOLUTION(top left side)-here u can adjust resolution and click-OK.
For XP-Place the cursor on desktop rightclick-Properties-Settings-Screen resolution(u can adjust/apply Pixels from here.)-ok.
Posted on May 24, 2011
  • AMD Master
  • 27,725 Answers
Click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes hope this helps
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
Input signal out of range
Hello
Boot the computer into SAFE MODE. Go to CONTROL PANEL - DISPLAY PROPERTIES. Change the screen resolution to a common size - like 800x600 or 1024*768 and save the settings. Reboot the computer.
Everything on the screen will be very large but you should be able to see the desktop and make additional changes. Go to CONTROL PANEL and DISPLAY PROPERTIES again, and change the screen resolution and click APPLY. This will change the resolution to the new settings and will give you the opportunity to revert back to the old setting if it does not work.
Once you hit APPLY - the screen will change. If you can see the screen, you will see the option to ACCEPT the changes or to REVERT back to the prior setting. If you do not choose anything, the system will revert to the prior setting automatically - typically in about 15 seconds.
Make changes to the screen until it appears as you want it, click ACCPET when you find the one you like.
Feb 22, 2012 | HEWLETT-PACKARD Slimline Desktop / AMD...
Is there a way to restore the computer to factory settings
you have to order a restore cd from emachines... or look in start -> all programs-> something that says make a restore disk.
Aug 29, 2011 | eMachines Black ET1352G03w Desktop PC with...
Se the size of the screen to full size?
Hi
You do not mention which operating system you are using.
There are 2 settings that can shrink your screen size.
Graphics Resolution Settings
Right click on empty space on the desktop > (properties) Personalize > (Settings) Display Settings > Left click and hold the slider to change the graphics resolution and test each setting until you find one you are happy with > Apply > OK.
Desktop Background Settings
Right click on empty space on the desktop > (properties) Personalize > (Desktop) Desktop Background > (Position - Stretch) How should picture be positioned - select > Apply > OK.
I hope this helps.
Aug 28, 2011 | Computers & Internet
Is the MSI 945GCM5-F 7.1 motherboard on-board graphic card compatible with LG Flatron wide screen? Up until now we had a GF card, but now it's gone, and using only the MSI we don't seem to be...
Hi
You don't say how big the screen is, what connectors it has [VGA (Analogue), DVI (Digital) or HD (High Definition)] or which Operating System you're using.
Right click on open space on your desktop.
Properties > Settings (XP)
or
Personalize > Settings (Vista, Win 7)
Left click & hold on the slider and slide to adjust resolution.
You are given the option to test and accept each setting change you make.
When satisfied, Apply > Yes > Ok. Then restart the computer.
If your screen is large and has Digital and/or HD capability and the above advice does not help you find a resolution setting thast completely satisfies you, you may need to consider a dedicated PCI-Express Graphics Card to upgrade your graphics performance and give you a wider range of resolution options.
Hope this helps.
Aug 23, 2011 | MSI 945GCM5 Motherboard
How do I increase screen resolution in PC mode running Windows XP Pro?
To change your monitor's resolution
1. Right-click the desktop, and then click Properties.
2. In the Display Properties dialog box, click the Settings tab.
3. Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4. Click Apply to have the new resolution take effect.
5. If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6. Click OK.
Hope this help.
Mar 21, 2011 | Computers & Internet
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
Dell Inspiron 1501 laptop with AMD 64 processor: Black Screen
Go to Control Panel/Power Options and check the settings. It's probably set to shut off after a period of time.
Oct 31, 2009 | Dell Inspiron 1521-JB Notebook
Laptop screne displaying 1/2 orginal size. need to reset pls
Jak, Go to Start->Control Panel->System->Hardware->Device Manager-> Display/Monitor. Select the monitor and uninstall it. The Go to Actions and select Scan foe new Hardware. Windows will automatically detect the hardware and install the driver for it. Save it and reboot into full screen windows.
Oct 26, 2009 | Computers & Internet
Processor Speed Dropped to 1.6GHz
Check your system bus speed, you may have changed it to 100 from 133. Look in your BIOS setup, you may have selected safe option instead of optimum settings.
Try this:
Control Panel >> System and Maintenance >> Power Options >> Change Plan Settings (For the current plan you are using) >> Change Advanced Power Settings >> +Processor Power Management >> +Maximum Processor State
Now make sure that it is set to 100%.
*Edit: Also make sure the minumum processor state is set to 100%
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
Apr 30, 2009 | AMD Athlon XP 2600+, 2.13 GHz...
AMD (axmd2400fjq4c) Athlon XP 2400+, 1.8 GHz Processor Logo
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
