Plustron wine cooler Display PCB model JC-130E/H
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 6 Answers
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Posted on May 27, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
  • 286 Answers
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Posted on Oct 08, 2009
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Posted on Feb 17, 2010
Our Wine cooler is beeping Whats up?
read the user guide that came with that model. good first move!
Feb 12, 2015 | Soleus JC-128 Wine Cooler
How do I get a PCB70323E1
Have you looked at the back of the board for burn outs?
Jan 17, 2015 | Emerson Fr24sl 8 Bottles Wine Cooler With...
I need to replace the broken glass door on my wine cooler. Where can I get one ordered?
look around for your model of wine chiller and may be somthing will pop up
Jun 22, 2014 | Soleus JC-128 Wine Cooler
Where can I get a relay for a wine cooler model jc 145b2eq? Uberhaus
its not the good number but try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC612BLP/3055/0169000?pathTaken=&prst=0&shdMod=DWC612BLP
Apr 24, 2014 | Furniture
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
Need to order PCB for Magic Chef wine cooler MCWC44DZ
Go to this page it will take you to a "dropdown" menu. Go to your model number and there will be 2 different PCBs in each category. One is for the door the other is the main. make sure you get the right one....match up the numbers you mentioned 155TD in yours which is the "pren" version of the 2 choices. Hope this helps you! http://mcappliance.com/partorder.aspx
J
Jun 27, 2012 | Magic Chef MCWC44DZ Wine Cooler
Uline 75WC Wine cooler: light works but fan and compressor do not come on. Wire cnnections are fine.
Does the compressor vibrabte? If not, the PCB isn't working and should be replaced or worst case is your compressor burned out.
Jan 22, 2012 | U-Line 75WC Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
Jan 20, 2008 | Haier BC112G Wine Cooler
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
