Question about Casio Executive B.O.S.S. SF-6500SY
Csaio sf 6500 sy dairy not working - Casio Executive B.O.S.S. SF-6500SY
Can anyone suggest any non dairy hot chocolate recipes for me?
You can basically substitute any non dairy products for milk and then follow the regular recipe for hot chocolate i.e. heat the 'milk' and add chocolate till it melts and stir in sugar to taste.
Be careful with the sugar amounts as some of the non dairy milks ie soya are quite sweet already.
You can try using almond or rice milk as well or just buy a non-dairy creamer.
Feb 25, 2013 | Wine & Spirits
Does eating dairy have any impact on snoring levels?
Eating dairy can cause a build up in mucus in some people and mucus blocks the nasal passages and airways which is one of the causes of snoring.
So if you suffer from extra mucus after you eat dairy and you snore at night, it's worth avoiding dairy products in the evenings and see if it helps.
Feb 13, 2013 | Health & Beauty
I have lactose intolerance. Which dairy products can I consume?
When you're lactose intolerant, you may cringe at the thought of eating dairy products.
But there's really no need. In this day and age, there are plenty of nutrient-rich dairy products you can enjoy, without suffering the all-too-familiar consequences. Those may be Yogurt, Aged cheeses, Low-fat dairy products in small amounts, Lactase-fortified dairy products, Dairy products eaten with a lactase pill, ..
To know how to treat it, see at:
Home Remedies for Lactose Intolerance Authority Remedies
Feb 04, 2013 | Cooking
Can dairy foods help me control my blood pressure?
Absolutely. Dairy food contains a large amount of calcium, potassium, and magnesium, which are important nutrient when it comes to controlling your blood pressure. According to a famous study called DASH (Dietary Approaches to Stop Hypertension), when people consume three servings of dairy products, their blood pressure is more likely to be under control.
Error code 6500
Error 6500 is a hardware error.In most case the logic board assembly is failed or an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Please rate your response.
Thanks, SF
Feb 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Mp 530 Eror code 6500 check printer
Hi ,
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Thanks,
SF
Feb 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Dairy products are seperating
Time & temperature. Even if kept at the proper temperature, dairy products will separate in time. Bacteria will also do it. If you drink from the bottle, the enzymes in your saliva will infest and break down the whole container. It's being digested in the container, like feeding baby food from the jar. The food in the jar becomes watery, because it's being digested.
Aug 01, 2009 | GE GTS22KBP Top Freezer Refrigerator
Casio Executive B.O.S.S. SF-6500SY Logo
46 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
