How to delete programs not properly installed in windows 7
    Problem Solver:
  • 10 Answers
If you went to your control panel and could not find it under the Add/Remove Programs there is a program you can use to help you. To get this done you should try using AutoCAD
Posted on May 24, 2011
How do I delete from my computer "Torch", from my computer?
Hi Joyce
you need to click start/windows icon(bottom left) then click on control panel. in the control panel you are looking for add/remove programs (windows xp) or programs and features (windows vista/7) double click this and find your program in the list which is displayed, click once on it then click uninstall (either above for xp or on the same line for vista/7) hope this helps.
Feb 18, 2013 | Computers & Internet
Tip
Tuneup utilities prefetch data deleted windows 7 slow
Basically, the prefetcher is a Windows component that speeds up the boot process and start times of programs by prefetching data.
I recommend you never delete the prefetch data.
If you or another program delete prefetch data or the folder, this can slow the computer down until the prefetch data is rebuilt. Windows rebuilds this each time on reboot and during program start ups.
If you are using a cleanup utility, turn off any options that delete prefetch data. In CCleaner, this option is unchecked automatically. TuneUp 10 does not have an option for prefetch data and does not seem to delete this data. You may receive a message when using the program that states, "prefetch data deleted" which is informing you the prefetch is empty.
-G33k
keywords
Title: tuneup utilities prefetch data deleted windows 7 slow
tuneup 10 prefetch, windows prefetch, windows 7 prefetch, windows 7 slow prefetch, windows tuneup prefetch delete, prefetch deleted, prefetch, prefetch data deleted, how to tune up utility prefetch data, prefetch data deleted tuneup utilities 2011, tuneup 2011 prefetch data deleted
on May 25, 2011 | Microsoft Windows 7 Ultimate for PC
Tip
How to fix a computer which is infected with viruses, malwares, spywares
In order to remove viruses, malwares, trojans, from the computer, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3.Scan your computer by using one of the antimalware, antispywares.Restart your computer in safe mode with networking.(As soon as you restart the computer, start tapping F8 and choose Safe mode with networking and hit Enter.)Use the link below to install antimalwares, antispywares .
http://siri.geekstogo.com/SmitfraudFix.php
http://malwarebytes.org/
http://superantispyware.com
http://www.simplysup.com/tremover/download.html
4.Stop Programs from running at the startup.As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)
You will see System Configuration Utility. Click Startup at the top right hand side corner.
Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box
if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.In order to remove startup from the registry go the followinglocations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolderRight
click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.Restart your computer.
5.Uninstall the useless programs(unnecessary toolbars like my web search,smileys,myfreeze toolbar). Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in
Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
6. optiize and reset internet explorer.Close all of the window, click Start, click Internet explorer, click Tools, Click Internet Options.Now,on the Internet Explorer properties window under General Tab, click Delete and then click Delete All. Now,click Advanced on the top right hand corner.click reset. click Apply and OK.
7.Update your antivirus, antimalware, antispyware program.
8.Update WindowsWindows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click
Automatic Updates tabclick Turn automatic updating on and click install updates.Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows
Update,click Turn automatic updating on and click install updates.
on Apr 07, 2010 | Computers & Internet
I've installed deep freeze v6.62.020.3058 and my antivirus has stop him from installing but deep freeze has alerdy installed some files witchi delete every modification and restore my desktop and
Click Start/Programs and find the programs in the list and see if there is an uninstall in the program's folder. If not, click Start/Control Panel and under Programs in the Control Panel you will see Uninstall A Program. Click it. When the windows loads all the installed programs, highlight the program you want to uninstall and click Uninstall or remove.
Mar 25, 2012 | Computers & Internet
I have original eyewitness encyclopedia space universe cd. but when i install it a error message shown in the computer. "[1058] the sound decompression software has not been install properly. please...
Hi ,
This product is not compatible with Windows 7 but it should run under Windows XP . If you are running under XP , I suggest you delete the program , reboot your machine and reinstall the program under Windows XP . If it still fails , you could need to reinstall Win XP or use the recovery disc . Launch the disc , select " install a new version of XP " and choose " repair " when you'll be asked to .
Make first sure you have installed SP3 and tested your program with XP fully updated .
Best regards ,
fanaudi .
Apr 22, 2011 | Dk Multimedia Eyewitness Virtual Reality...
How to downgrade from windows 7 to windows xp
not recommended but you either do a fresh install deleting every thing on the drive your installing on. or you can upgrade and windows 7 will save every thing on the drive to a folder called windows.old but your settings and book marks and programs wont be on windows seven...( you might be able to run the programs from the directory)
Mar 29, 2011 | Computers & Internet
I have just got a new computer. A Gateway PC running Windows 7/ 64 bit. After installation of ONE I get a dialog box stating " cannot execute machnm1.exe - What can I do to complete the installation?...
I'm not familiar with ONE, and am assuming it's a software program.
Try running 7 in XP Mode for proper emulation of the program in question in a 64 bit environment when BIOS requests Machnm32.sys which is probably the culprit (Machnm64.sys in 64 bit environments). Both should be present. This should allow you to continue as many older softwares will not function properly in the 7 environment but, 7 has many built in features to allow for this. Your program may not have the proper drivers to operate in a 64 bit system/chipset.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Hope this helps.
Nov 26, 2010 | E-Press ONE SE
I bought a dell desktop with windows 7 installed. but i now want to install windows xp on that computer. but when i insert the xp cd and select install windows xp option i get an message somewhat like this...
I believe the only way would be to remove Windows 7 from the computer. If the hard drive with windows 7 on has any programs and files you would loose them during the proccess. If you want to run programs that are not compatible with Windows 7, I think you'll be able to tell the computer to run it as XP, or I should contact Microsoft if you have problems with Windows 7 and other programs. You should look at all the avenues before deleting Windows 7 though.
Oct 28, 2010 | Microsoft Computers & Internet
How to install windows 7 operating system
To Install the Windows 7 Operating System (Win 7 OS):
Instructions for a "Clean/New Windows 7 Installation:
AFTER BACKING ALL YOUR DATA THAT YOU DON"T WANT TO LOSE, Do the Following :
1) Insert your Genuine Windows 7 System Disc (Retail or OEM System Installation Disc).
2) Close down all programs and restart your computer.
3) As soon as the computer restarts, you should see a prompt that says something like this: "Press any key to boot from cd/dvd"
....So press any key!... This will boot to the installation disc and prepare for installation or repair (we are going to be installing windows, so ignore the repair options you see on the screen).
*If you don't press a key in time, you will see that the computer will attempt to boot from the hard disc drive instead... if that happens, restart the computer and press a key when prompted.
4) Depending on your particular Windows Version, you will see a prompt that says something about "Do you accept the license terms?" Click "Yes" or "I accept", etc.. and continue on...
5) Choos Custom or Advanced Settings (the other option is for an upgrade..)
6)Select the desired hard disc drive, (HDD aka Hard Drive), Select "Drive Options", and follow the onscreen instructions "Delete the partitions" (Do not Leave another windows installation on the same hard disc drive, unless you are experienced and know how to "dual-boot" properly!) Delete the Partitions.
7) Now choose to install windows (be sure to select the newly deleted empty (unformatted) partition. Windows 7 will automatically format the drive for you and will begin to install windows 7. Follow the onscreen instructions and within a half an hour or less (depending on your hardware) you will be finished, just be sure not to leave the computer unattended while performing a windows installation, since it requires your input quite often to proceed.
That's pretty much all there is to it!.. if you have any more trouble...
Google it or Bing it.... Search Engines are awesome!.... Enjoy!
*NOTE- If your windows 7 disc is a "Upgrade" disc, then you must perform an upgrade while running your previous/older windows version, since Windos Upgrade Discs aren't bootable, they simply patch the older version, replace system files, etc... to transform the previous windows installation into the target/newer version. If you want to perform a clean install, be sure you own a Windows 7 Installation / System Startup Disc.
Jul 06, 2010 | Intel Motherboard
Pets Don't Have Faces
Check that you are running in compatable mode. Since Windows 7 is so new not all programs run properly so you should have a link to run the program in a compatable stage. If not check and make sure your program is compatable with Windows 7. You may have to reinstall the program and you will probably get a message to install in a compatable mode. If you do make sure you install in that mode then the program should work. Windows 7 is like when they first came out with Windows Vista there are a few bugs that they are still working out and that is probably what is causing the problem.
Jan 10, 2010 | Ubi Soft Petz: Dogz 5 and Catz 5...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
