Question about Cell Phones
My blackberry track ball doesnt scroll upwards, but can scroll sideways and downwards comfortably.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 104 Answers
Ball needs to be channged
Posted on May 24, 2011
My blackberry 9000 won't scroll down
Hi there. You can replace the trackball on the Bold 9000 by taking the back cover off. You will need to take the battery out and undo a few screws in order to get the back plate off. Once the back plate is off, you can clean the track ball using rubbing alcohol and a Q-Tip. This will help with your scrolling problem. If you aren't comfortable with this, a mobile repair shop will help you. Good luck! Alex
Jul 15, 2011 | Cell Phones
My blackberry has problem with rollerball not responding when pressed
The balls get clogged with grease and skin from your finger over time. turn off the blackberry or pull the battery. Get rubbing alcohol and a cotton swab and rub the top of the ball getting off as much of the black as you can. Rotate it slightly and do the same until the entire ball is done. Then push quickly upward against the ball, downward, left, and then right several times in each direction.
Replace the battery, start the phone, and see how it works.
Apr 11, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Rollerball downward movement does NOT register. Upward OK. Click OK.But cannot scroll downwards
Same problem I had. Remove the ring around the track ball assembly. and remove the track ball assembly frrom the phone. Clean the ball well with a swap and alcohol. Make sure you put the assembly back in the same way it came out. Put the ring back on and you should be good to go.
Nov 24, 2009 | RIM BlackBerry Curve 8310 Smartphone
My track ball scrolls on my blackberry curve but niether the keypad or the track ball works. how can this be soved without buying a new phone?
try cleaning the track ball with a qtip dipped in alcohol or nail polish remover.. It could be that the track ball isn't "reading" correctly due to oil, etc.
Nov 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
My nokia n91 8gb's joystick doesn't scroll upwards and downwards while it does sideways. also the call button(green) does not work
You need to get it repaired from a Nokia Service Center near your. This is a hardware issue.
Regards,
Waqar
Aug 03, 2009 | Nokia N91 Cellular Phone
Tracking ball not working after cleaning it exactly as directed
do a battery pull.. wait 30 to 60 seconds, the reboot up you blackberry, and firmly press down on the tracking ball as you scroll up
Jun 11, 2009 | RIM BlackBerry Pearl 8100
The track ball on my black berry pearl doesnt scroll down
yes sure!
just take it apart and clean the track ball area with amedical alcohol and brush, remove dirt from it!
plz give a good rate
that happend with mines once!!
Mar 25, 2009 | RIM BlackBerry Pearl 8100
Blackberry rolling ball will not roll down
Cleaning the track ball on blackberry phones. Remove the metal ring then the ball mechanism remember how you removed it because it needs to go in the same way. You can also try removing the battery from phone taking a qtip with alcohol the higher the percentage of alcohol the better. and wiping and rolling the ball around even without removing it from the phone. this usually helps unless the ball is extremely dirty. Below are step by step ins for removing the ball. just follow the link
Removing blackberry tracball (non BOLD)
Dec 28, 2008 | RIM BlackBerry Pearl 8100
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
