Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Misfires and does not start, now
For some wierd reason, my lawmover does not start, now. Before this state, I remember it used to misfire few times. Is it issue with the mower or the electric connection from the wall into the mower?
I open the black plastic hood into which the main wire runs, connectivity looks all fine.
Any ideas?
-BG
    Champion:
  • 313 Answers
Check out the brushes may be they are too low.
Posted on Aug 21, 2008
Jerking and cutting out on a suzuki vitara 1.6 1995
G16 misfires there are over 50 causes,
do you have tools? and gauges, and meters?
overheated before, so not now right?
new engine, so compression over 170psi, ? at sealevel?
seems its not in USA< right>? (if not , the many parts are different that is why I ask country)
our 95s are called sidekicks and trackers.
im guessing you are in canada posting to a USA forum?
jerking and cutting out. when?
hot engine cold engine, or both????
idling in park (is it AT? trans?)
idling in drive.? misfires,. at all times.
driving in gear,? only.
cruising, only misfire?
does it misfire, accelerating or wide open throttle. only?
only up hills , only in some gears?, only in turns,
ECU operates in many modes, (as above) and these facts aid diagnosis big time.
or is jerking and cutting out not the engine, but the 4 speed trans doing that. as any AT sure can do. (gear, flare ,gear ,repeats)
27 reason just here.
http://www.fixkick.com/misfiring.html
my guess, is battery is 13.3 to 15vdc running.
that it's bad spark got new cap,rotor wires and spark plugs.?
old 21 year factory HV wires are helpless, get some BOSCH mag wires, on this G16, best there is for this weak spark engine.
did you gap the stock class plugs at .028" or leave them at NGK .045"
which is wrong, dead wrong. are the plugs OEM plugs stated in the NGK catalog, free to read online? or what ever brand you use?
Did you time the cam right.? not using the false markes on cam cog?
did you then after that, time the distributor to 5deg. btdc or as your book states? using the timing freeze jumper and the timing light?
some are 5deg others are 8. degrees. depends on state or country.
if i knew all ways it misfires, id be more savvy but dont.
good luck..
PS:
id pull all 4 sparks out.
1: color, is tan? ok,.
2: coal black.?
3: black oil soaked.?
4: fuel soaked. even dripping , injector stuck open. on 1?
5: green antifreeze soaked.
6: damaged.
1 bad or all 4 or what, this is called READing the spark tips
and is a HUGE CLUE.
Sep 10, 2016 | 1995 Suzuki Vitara
When fuel is low and loaded it misfires
one if the reasons for misfires is low fuel pressure/ pump
when loaded there is a requirement for more fuel and if the pressure is too low then misfiring occurs
if it doesn't happen when the tank is full then that will be a reasonable expalnation
Feb 09, 2016 | Cars & Trucks
Engine will start and cut off after a few minutes
but does the fast right foot save the stall.
cut out has 2 meanings.
misfires. or stalls.
use those 2 words and all is 100x better.
and for sure misfires do cause stalls.
as does 50 more reasons.
wana guess or test?
Jul 25, 2014 | 1997 Jeep Grand Cherokee
How often do i change oxygen sensor
You change the Front or Upstream Oxygen Sensors
every 100,000 miles or sooner, if they fail or slow down,
on ALL Vehicles
The Rear Sensors can stay until they fail
Doubt the Cylinder Misfires are from the O2 Sensors
You have to look at the reason for & correct the misfires
You should have a steady or flashing dash light on
If so, stop using it before you ruin the converter & get
it diagnosed & ALL Vehicle problems resolved at one time
May 15, 2014 | 2006 Dodge Stratus
2000 Dodge RAM 1500 Van, Hesitates and misfires after initial startup
try 0 timing carbon in your pistons can create similar problems,special wen engine is hot.
Aug 10, 2012 | Ford F-150 Cars & Trucks
Po304 po307, i think my engine coils keep going out i also have a po420 code
You may have 1 bad coil not both #3 & & #7
You also have a bad exhaust converter from 10
years of on & off misfires
The PO420 is (Bank 1) Passenger side
Fix the misfires
Replace both Converters
Replace all 4 O2 Sensors
Converters should have lasted a few more years
A cop ignition coil is $59.00 & takes about 15 min to put in
No reason to pay someone $500.00
Jun 17, 2011 | 2000 Lincoln LS
My 2004 Suzuki Forenza misfires when I start it after it's been parked for a while. It causes the error code P0300 (Random multiple misfires). After starting the car and driving it or letting it run for a...
leaky cylinder headgaskets!!!! car sits usually after just being driven coolant under pressure finds leak in gasket seeps into cylinder mind you it only takes a little dribble or two next morning you go out get in start up car misfiring,running lil ragged then begans to smooth out. stop @ store a few moments later come out restart car no miss runs fine till next morning sound fimilar have them checked
Mar 17, 2010 | 2004 Suzuki Forenza
1999 Dodge Intrepid, intermintently misfires, runs
take to autozone and have them check the engine light code to start it's free
Nov 20, 2009 | 1999 Dodge Intrepid
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
