Question about Philips GOGEAR SA6045 MP3 Player
Model sa3346/37 left headset is going in and out
  • 8,596 Answers
Common problem with mp3 players - get whole player replaced, or watch the YouTube videos on repairing mp3 player headphones (probably won't work) - your choice.
Posted on Aug 26, 2008
Left ear piece is not working
There could be a broken wire or connection in the left earpiece.
Jul 08, 2014 | LG Tone HBS-730 Bluetooth Headset- Black
Right and left sounds are off
Have you pressed the plastic circle on the left ear? Hold it for 2-5 seconds until you hear a double or triple beeping sound and a colour of light should go on on both ears!!! Hope this helps! ;)
Feb 01, 2014 | PDP Afterglow Universal Prismatic Wireless...
No sound when coming from the headset
Check the compatibility setting on the left side of the Plantronics CS70 base, number "1" should be in the 3 O'clock position. Also check the cable connections, unplug and re-plug the cables. If the headset is dead, then the internal battery may be worn out and it may need to be replaced. The headset replacement model is 72910-01. Below is a link for the user guide to help with the compatibility settings and adjustments, as well as a link to the newer Plantronics headset that replaced the CS70.
Plantronics CS70 User's Guide
Plantronics Replacement Model 72910-01
Good luck from Headsets Direct!
Aug 26, 2011 | Plantronics CS70 Wireless Headset
No sound in lift side
If the cord going into the headset or the headset itself has not been damaged, check the settings for the audio device on your computer to make sure the sound is still equally balanced between the left and right channels.
Mar 30, 2011 | Plantronics - Usb Multimedia Headset...
Logitech cordless headphones model #A-00006 has problem with left headphone cutting out. Please help.
Hi All,
I have a
are Logitech Model # A-00006 and the wireless antenna unit is Model # A-00007.
Recently I am noticing that what is normally a stereo experience of listening while I am in on a Beacon conference call is becoming a mono experience (only the right earphone). Not sure if this is because of bandwidth fluctuations or a problem with beacon or a problem with my headset, but it doesn't seem to do it when I'm in a 1:1 call.
Odd thing is I don't hear it cutting out when I am making a direct call - only when it's a multiparty Conf call.
Thank you inadvance,
B1L
Jan 08, 2011 | Logitech (980174) Headset
How to increase ringer volume of panasonic kx-tc2100bx model cordless phone
Go to Menu > Ringer Setting >Ringer Volume > use Right or Left arrow to adjust the volume of the ringer
thank you
Aug 31, 2010 | Panasonic Cordless Phone Headset Headset
The sound comes and goes from right part of headset
The left/right problem could be a bad connection on the red/white XBOX cables. Check to see that they're plugged in properly and not loose. You can also try plugging an MP3 player into the red/white jacks to see if the problem is with the headset or the XBOX. If it works ok with your MP3 player, then the headset is working fine.
You can get a new headset controller cable on our web site. Click on Replacement Parts in the left menu for the headset model you own (X1, X3, or X4).
Jul 04, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
Plantronics cs70 nc stop working
Make sure that the power is connected to the headset.  You can tell it's connected because there will be a red solid light on the left side of the front of the charging base.  Check the power cord for any frays and make sure it's plugged into the wall.  If it is, then try the following:
A system reset:
1.  Lift the headset off of the base. 2.  Make sure the headset is turned off.  The green light will not be on on the base. 3.  Hold down the minus button at the same time as the call answer button on the headset.  Hold them down for at least 10 seconds.  An orange light on the headset will flash several times.  It should go off when you let go of the buttons.  If the orange light stays solid, push the minus button once. 4.  Put the headset back in the charging cradle.  Leave it for 30 seconds.  Lift it back out of the cradle and try using it again.
Oct 01, 2008 | Plantronics CS70 Wireless Headset
I need help installing a logitech headset onto my playstation 3
go to settings/ "Accessory Settings">"Audio Device Settings"> make sure that the level is "5" and it "Inputs" to Logitech USB Headset"and "Output" to "Logitech USB Headset". Then once your in the online lobby of Resistance you go to "Option"
"Audio Device Settings"and it "Inputs" to Logitech USB Headset" and "Output"
to "Logitech USB Headset". And to talk in Resistance just press and hold "L3" (left anolog stick)
Aug 12, 2008 | Video Game Consoles & Games
Philips GOGEAR SA6045 MP3 Player Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
