Question about Cell Phones
Can u help m plssss When i arrive her at HONGKONG i just roam on my no. when i check it no network . i can not use it. plsssssssssssss help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 104 Answers
Service is weak
Posted on May 24, 2011
Please can you tell me how to turn off roaming? I'm using pay as you go.
To turn off roaming go to your settings app, wireless & networks, mobile networks, data roaming, and turn data roaming off. How to turn data roaming and data services on off on my Samsung Galaxy...
Dec 03, 2015 | Samsung S5600 Cell Phone
What is data roaming
Data roaming is simply cellular internet data but using out of your country. For ex. when you go on holidays to Spain you can use cellular internet from roaming. Roaming is for calls and sms too. And important thing is that roaming is much more expensive then normal in your country
Jan 08, 2015 | Cell Phones
Stop roaming
If you need to stop Roaming phone signal,You should keep in mind the following instructions
1.Turn your voicemail off
2.Just switch Data Roaming off with a help of your service provider.
3.Try to access network through Wi-Fi while visiting abroad.
4.You can also avoid roaming by use the local carrier sim card,which is available in that country.Before put local carrier,Make sure your phone is unlocked or not.If it's restricted by some network,try to unlock your phone using
WickedUnlock.com
Mar 02, 2014 | Nokia 5800 Cell Phones
Huawei problems
Yes u can use it but u have first see if the phone use sim card so u can go to the right phone service yhe they will ooen it for u and u good to goo
Feb 28, 2014 | Cell Phones
Can't connect to network
Don't know if it is the same but I discovered that the triangular icon on
my phone screen was there to show that 'Roaming' was on. When I arrived back in UK it disappeared.
Mar 25, 2013 | Palm Pixi Cell Phone
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
My blackberry bold stopped working on roaming network
1.INSERT THE SIMCARD IN OTHER MOBILE AND TRY ....
2.IF SAME PROBLEM PERSIST CHECK WITH THE SERVICE PROVIDER OR CARRIER AND REQUEST FOR ROAMING SERVICE TO REPROVISIONED....
Aug 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
Same problem plssss help us
the PIN will depend on the telecom who provided you the sim. the asking of pin is commonly an option on the phone. check the manual of your phone and see how to turn off PIN code option. Hope this helps
Jul 09, 2009 | Computers & Internet
Red triangle on left hand top corner - K800i
hi
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
May 25, 2009 | Sony Ericsson K800i Cellular Phone
Connecting to foreign network when abroad
Hi There, First of all u have to make sure that u get the roaming facility from your carrier put on before u travel. Before or when u arrive u have to make sure your phone is set to automatic in your network setup... Settings-network-network setup-automatic Your phone is quad band so u'll be able to connect to whatever network is available in Greece. Sam !
Jul 18, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
