Question about Microtoolz PenDrive Autorun
Hello, i have sandisk cruzer blade 4 GB pen drive. It shows I/O error while copying files to it. I tried with some soft wares so that i can copy up to 12 MB files. So i understand proper repairing will clear all problems.please help me
  • 670 Answers
You can reformat it as Fat 32 and should fix your issue. i have the same model and type , and its what i had to do
Posted on May 24, 2011
My pc doesn't show sandisk cruzer blade 4 gb pen drive whereas it shows others
Sometimes, windwos OS, give same drive letter to different devices, and when you connect both, one is not showing. So, you need to go in to Disk Manage (right clic on "My PC", clic on Manage") and verify if you can assign a different driver letter to your pen drive.
Oct 01, 2012 | SanDisk SDCZ50-004G-P95 4GB Cruzer Blade...
MY 8GB SANDISK CRUZER BLADE PENDRIVE NOW SHOWS WRITE PROTECTED...PLEASE HELP IF U CAN........
My 8 Gb pen drive now right protected how can i remove the write protection pls.....................Pls..............say the solution
Sep 13, 2011 | SanDisk Sansa e270 MP3 Player
Hello sir, my pen drive(San disk cruzer blade 4 GB) shows I/O error while copying files to it.I tried to repair it with some soft wares so that i can copy files up to 12 MB.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
May 24, 2011 | Computers & Internet
Hello, I have Sandisk Cruzer blade 4 gb pendrive. But now it shows I/O error while copying data to it. please give a solution.
Copy all the files from it to your 'C:' drive, and burn the files to one DVD-recordable disk.
Then, responsibly recycle the SanDisk, and spend $10 to buy a new flash-drive.
Copy the files from the 'C:' drive, or the DVD disk onto the new flash-drive.
Keep multiple copies of your files, just in case this "new" flash-drive also "fails".
May 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sir i has purchased in last 18 month 8 gb pen drive and this time time pen drive is not show on 7 gb data copy any computers so sir plz check my pen drive ok azad 9988629625
This is normal. When windows "prepares" the drive for access; it uses a certain amount of space up for 'indexes' of files (much like table of contents of a book.
Sep 02, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Am trying to transfer DVD disc to Sandisk flash drive. What's the process? Thanks V
it sounds like you need to creat an .iso file from the dvd then drac and drop. is you flash drive 4 Gb
Jun 24, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 4gb pendrive not working
Best thing to do is format the drive. Dont go for a quick format
Jun 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
New cruzers will not accept files
Please format the drive first then it will work when first time it is working with pen drive are ant hard drive you should format the drive then try to copy the files with NTFS are FAT formats
Jul 01, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
93 people viewed this question
Top Microtoolz Computers & Internet Experts
David Payne
David Payne
Are you a Microtoolz Computer and Internet Expert? Answer questions, earn points and help others
