Question about HTC Cell Phones
I accidentally turned off my Bluetooth on my HTC Wildfire, and now when I check the 'turn on' Bluetooth box, it never actually turns it back on. What do I do?
    Problem Solver:
  • 16 Answers
Try removing the battery on both devices
Posted on May 24, 2011
I cant receive files through bluetooth on my htc wildfire! atleast a little picture, a option appears to accept file I click accept then phone decleares 'sending fail' please tell me the solut
software problem or change the settings in Bluetooth menu something like always remember or always available sort of. or see your phone memory.
Oct 19, 2012 | HTC Wildfire Cell Phone
Htc wildfire locked too many pattern attempts
Turn off, turn on again. Get on a computer and access your email account, make sure that's in order. Turning it back on, the phone i mean, eliminates the timer. You wont have to use your email to access your phone, usin instead the normal pattern.
If it wont turn, off, remove the battery, put it back, and turn on the hone ffter waiting between thirty and sixty seconds.
Jul 21, 2012 | HTC Wildfire A3333 Unlocked Smartphone...
Htc wildfire not fully charging always show the led red
When want to charge htc wildfire it is better you turn the phone of before charging. Plug in the charger and charge for about 20mins to 30mins then remove the charger pin-mouth for like 10secs and plug it back in. soon the red light will turn green in less than an hour..
Jul 16, 2012 | HTC Wildfire
How to install softwares on htc wildfire
If you have application files (*.apk) on your computer, you can use HTC Sync to install them to HTC Wildfire S. It is strongly recommended you install only applications that you trust.
Before you begin, make sure that HTC Wildfire S is set to allow applications from your computer to be installed toHTC Wildfire S. To do this, press howtoimage.aspx?id=88185 while on the Home screen, tap Settings > Applications, and then select the Unknown sources check box.
  1. On the Device panel, click Overview.
  2. Click Application installer.
  3. Browse for the application file on your computer, and then click Open. The installation process starts on HTC Wildfire S.
  4. Check the screen on HTC Wildfire S to see if there are additional instructions to complete the installation.
  5. After installation is complete, you can click Disconnect.
  6. Safely remove HTC Wildfire S as required by your computer's operating system.
Jun 01, 2012 | HTC Wildfire
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
How to twitter
Using the set up manager, you can set up all your social networks before you start using the Wildfire.
The HTC Wildfire allows you to set up Facebook, Flickr and Twitter accounts for use with HTC's Friend Stream and HTC Peep social networking services.
You can either set these up using the setup manager when you first turn your Wildfire on, or do it later
Setting up social networks with the set up manager
The set up manager will appear when you turn your Wildfire on the first time, or after you've carried out a factory reset of the device.
When the social networking setup screen appears, simply select the social networks you use and enter your username and passwords.
Each time you successfully set one up, you'll return to the set up screen to add more accounts.
When you've finished, tap on next.
Setting up additional social networks
If you want to add more social networking accounts, or didn't use the set up manager to add accounts, you can do this later through the Accounts & sync sub menu in Settings.
To set up a new account, select Add account.
Here, you can choose which you want to set up for use on your Wildfire.
To use the Facebook widget on your Wildfire, opt for the Facebook for HTC Sense option.
Enter your username and password for the account. If your log in email address is set up on your Wildfire, it should appear as you start typing to save you typing it in again.
Beware though, we found that we had to manually change the address from the default @googlemail.com to @gmail.com before it successfully signed us in.
When setting up your Flickr account, you will be required to confirm you're downloading the HTC Flickr downloader from a trusted source.
Opt for the second option as the first is sometimes regarded as untrustworthy and access to Flickr may not be granted.
When you've set up your accounts, you're ready to start using Friend Stream.
Dec 02, 2011 | HTC Wildfire Cell Phone
How to set uo htc wildfire as10e
connect the two phones via bluetooth and transfer, I couldn't believe how easy it is!
Nov 27, 2011 | HTC Wildfire Cell Phone
How do i connect to the wifi
If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
  1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
  2. Select Wi-Fi settings
  3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
  4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
  5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
  6. If a password is required, you'll be prompted to enter this before connecting
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
Jul 28, 2011 | HTC Wildfire Cell Phone
My auto rotate screen didn't work normally
I just bought a new HTC Wildfire. Even though, I checked the box under settings/orientation to have the screen rotate when I turn the phone, it does not rotate. It will with a photo, though the size of the photo stays the same. Can anybody help?
Mar 15, 2011 | HTC Wildfire Cell Phone
How do i turn on bluetooth with a htc wildfire
Bluetooth basics Bluetooth basics Bluetooth is a short-range wireless communications technology that allows devices to exchange information over a distance of about eight meters without requiring a physical connection.
Turning Bluetooth on or off Turn off Bluetooth when it is not in use to conserve battery power, or in places where using a wireless device is prohibited, such as on board an aircraft and in hospitals.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Select or clear the Bluetooth check box.
Mar 05, 2011 | HTC Wildfire Cell Phone
Cell Phones Logo
110 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
