Question about Whirlpool Washing Machines
Kenmore elite catalyst washer model 110.20092993, made by whirlpool. while running diagnostic tests for the recirculation pressure switch, the tub fills with a t2 code but once it's full and the water valves close it displays a code 5p and stops the test. Also, while running the tests I accidently hit the express wash or whitest whites button and the machine went thru a strange series of cycles and stopped with a 4c code. My latest attempt to run the recirc test, the machine starts to immeadiately spins at high speed and water recircs, but pushing the regular button doesn't change anything untill 2 or 3 pushes and then it stops and ends the test mode. Could I have a bad controller board or is it in the pressure recirc circuit?
4 Suggested Answers
SOURCE:
vest6
  • 196 Answers
SOURCE: not recirculating
"0d" refers to an "open door" problem. Need to chceck the lid switch to insure it is functioning properly.
Posted on Jan 12, 2008
  • 145 Answers
SOURCE: fisher paykel gwl11
Hi Alan.. usually if there is a problem where the diverter valve is not sensed by the machine control, it will throw a fault code and beep and not complete the cycle. There should be a tech sheet under the control panel. Did you make sure you properly re-connected the two orange wires on your new diverter valve?
I certainly have encountered several over the years where the control stops puting voltage to the diverter in recirculate mode.
If you want to be able to use all the cycles on the machine, then you need a new control board. That is part #420094USP and can be purchased from Fisher Paykel Parts direct;
http://fisherpaykelparts.net/index.php?categoryid=111&productid=26
If you need to do laundry in the meantime, use the PERMA PRESS wash cycle, it should work for you, as that cycle does not use the diverter valve.
Also inspect your water pump and make sure it isnot wet or leaky, as this can cause the machine control to either short out altogether or lose functionality on some cycls such as you are experiencing.
I hope this info is helpful to you.
Posted on Dec 15, 2008
  • 6277 Answers
SOURCE: Maytag washer LAT8035AAE, won't agitate
Some makes and models of washers rotate without doing anything if there is a problem with drainage.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 07, 2011
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Tip
Washing machine showing F4 on display.
<span>Hi.<br /><br />This tip applies to Whirlpool built washer, including Kenmore and other brands.<br /><br />F4 means that the problem is caused by a defective pressure switch. The problem is often coming with troubles in the spin part of the cycle.<br /><br />The following is an extract from the washer service manual:<br /><br />"F4" flashes and the cycle signal beeps when the recirculate pressure<br />switch is not working properly during the Catalyst, W ash or Soak cycle.<br />If "F4" is flashing, check the following:<br />- Plugged recirculate hose (black hose).<br />- Plugged or disconnected air tube (clear tube).<br />- Wires to the recirculate pressure switch disconnected or not<br />connected correctly.<br />- Failed recirculate pressure switch. Switch (black wire, tan wire)<br />contacts should be open with pressure applied and closed with<br />no pressure.<br /><br /><br />Try disconnecting power by tripping the circuit breaker or disconnecting power cord for five minutes. If that does not clear the error check the thin clear rubber hose connected to the pressure switch and extending into the tub. Try blowing into pressure hose and clean it. If that does not fix the problem replace the pressure switch.<br /><br /><a href="http://www.searspartsdirect.com/partsdirect/index.action">To locate parts and diagrams, please enter the full model number, as witten in service tag, in this website.</a><br /><br />Regards.<br /><br />Ginko.</span>
on Jan 13, 2011 | Washing Machines
Tip
F20 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F20” error code.
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please refer to my profile and use the “Ask Me” feature if you require additional assistance.
on Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer (spprox 6 yrs old) will drain, but won't spin. Gives error F4
Hi.
No spin and F4 usually means that the problem is caused by a defective pressure switch.
no pressure.
Regards.
Ginko.
Jan 13, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Tip
FH Error Code on Whirlpool Duet & Kenmore Elite Front Loaders
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “FH” error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
on May 22, 2008 | Kenmore Elite 45986 Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Top loading washing machne F4 error. (110.20052994)
It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
178 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
