Question about HP Photosmart C6180 All-In-One InkJet Printer
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
  • donk59 May 25, 2011
    dasssfett
    What was it you did,because I didn't find the solution ?
    Thanks
    Donk
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
Posted on May 28, 2011
Unable to send, copy or send fax
Sounds like the scanner bulb is burnt out or it's not able to move the scanner sled.
It should be saying "scanner error" as well. (and I think you meant unable to scan, copy or send fax)
No fix unfortunately other than getting a replacement unit (which I believe now is the 8500 premiere)
If you need a replacement, your timing is good, they are $200 off right now, and selling for $299.
Your unit as it stands still makes a good printer and will receive faxes, and you CAN send a fax as long as you do it from the computer.
Feb 28, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Hello, I have an HP Photosmart C6180 All-in-One Printer, Fax, Scanner and Copier. It seems that as soon as I turn it on a message comes up: "Fax Failure" Unable to Send or Receive Faxes" This message has...
try ti perform steps as ---->Disconnect the power cable from the back of the printer and then press the power on button for 3- seconds and then at the same time connect the power cable at the back of the printer and then try to turn on the printer and then try to make copy from the printer
Aug 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer will only print, not copy fax or scan
It is possiblethat the all in one solution software you used in XP doesn't work with Vista, after some update or other. You did the right thing by uninstalling and reinstalling. Make sure you have the correct driver from the HP site..
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C6180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Nov 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 AIO Scanner Failure
hi,
The "Scanner Failure" usually refers to the hardware of the printer. try to do a reset.
Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
If the issue still not resolve, please call HP 1-800-474-6836. Also check the warranty status of your printer.
thank you so much.
adonscott
Jul 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
434 people viewed this question
Seeker5211
Seeker5211
