The sound is shutting off when theres a loud noise in the movie. I changed the cables and its still doing it . i have it set up through digital optical. is the tv causing the problem or the receiver?
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 24, 2011
Sound issues when connected to PS3 with HDMI
I don't think you can hook a PS3 to 350W projector. You are maxing out the PS3 output. Good luck with it
May 03, 2014 | Optoma PRO350W Projector
A very loud static pop noise
i would suspect that you may have a defective coupling capacitor in your preamp or amp, try using another source input or and a different amplifier to help localize the fault, I do not suspect the cable as being the fault, and is more likely and amplifier problem
Apr 27, 2010 | Pioneer PRO-200 60" Rear Projection...
Tuner Keeps Turning Off when a Loud Noise is Played
It's a receiver, not a tuner.
Clearly something is overloading it or forcing it into self protection.
What else is drawing power from the same souce as the receiver, or from its convenience outlet. There IS a limit to how much current it will support.
Try checking the speaker connections and their impedance to make sure it's not unacceptably low.
Apr 02, 2010 | Audio Players & Recorders
The background noise in a movie on Tv is so loud I can hardly hear the conversations. I have tried the audio menu. Normal, Wide, Low ..They all sound the same.
GO again into the customer menu and look for something that says Hall, Surround etc--I have seen this before--usually it is a setting that creates a problem where the background sounds are so loud you cannot hear the people talking......go thru every section of the menu--I be you will find this is your problem.
Let me know what you find--I am here to help people. I do not think you have a circuit problem--only some thing in the menu has been set to the wrong place.
If this has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 21, 2009 | Toshiba 42H81 42" Rear Projection...
DVD movie background sound too loud to comfortably watch!
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Aug 24, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Sound
To everyone having sound trouble... there is a solution! First make sure your TV is OFF. Unplugg the 2 main cables going into the DVT 412 for 30 seconds. Then re-plugg them. Press down for a few seconds on all the BLACK tabs connecting the sound wires and release. Without a disc in the player... and the TV still OFF, turn the power on and immediatley hold the down the STOP button on the DVT412 for 5-10 seconds. Your picture, vocal and backround sound will return to normal. Feel free to make changes to the sound now! Happy tuning... GO STEELERS! LOL!
Sep 05, 2008 | Zenith DVT412 System
Subwoofer
often your sub need to be change because of its malefunction.
Mar 09, 2008 | JVC TH-M303 System
YAMAHA HTR 5660 MAKES POPING SOUND WITH LOUD NOISE AND BRIGHT LIGHT
Looks like you've got the best connection available - initially I thought it might have something to do with decoding the prologic signal from the analog input, but obviously not! And since you've got the audio separate from the video it is unlikely there is any interference from the video signal in the cable. Have you tried a different DVD player (I reckon that is most likely)? Also try connecting the video signal DIRECTLY from DVD to the TV if you aren't already doing so (you are anyway aren't you - the HTR 5660 doesn't have HDMI out does it?) Finally, if you have some spare cables around, try changing them - see if you get the same response when using component video cable instead of HDMI.
Jan 26, 2008 | Yamaha HTR-5660 Receiver
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
System shuts down whenever there is a loud noise on a DVD
I had the same problem. Found out the wires were in contact with one another on one of the speakers.
Nov 26, 2006 | JVC TH-M505 System
19 people viewed this question
 Grubhead
Grubhead
