Question about Ricoh CL4000DN Laser Printer
Error code SC543
Have replaced the fuser unit, and reset the printer several times but still come up with this error. Ricoh support wants to send out a tech for $200 per hour plus parts (no limit on the hours) after they told me to buy the Maintenance fuser kit for $200. Is there anyone anywhere that can help fix this problem without charging a arm and a leg or should I just buy some other brand?
    New Friend:
  • 63 Answers
Press .....clear modes 1-0-7 and hold clear/stop until the screen changes to service mode then unplug the machine and plug it back in and turn it back on Good luck
Posted on May 04, 2009
Ricoh Aficio SP 3510DN sc 543
SC543 high temp error.
Reset fuser error. If it reoccurs could be a bad ECB(engine) or PSB(powersupply) board. To reset fuser error go to maint. mode
Hold stop/start & escape and turn power on. OK. look for reset fuser error.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
Sp210 sc543 error cod
might be fuser is bad repair or replace then reset code. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
Mar 23, 2017 | Ricoh Office Equipment & Supplies
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
Error sc543 sp c320dn
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Feb 17, 2012 | Ricoh SP C320DN AllInOne Laser Printer
The wrench icon is on and code SC543-00 show up in the screen
That code indicates a fuser overheat error or hot roller fusing lamp overheat. Refer to your manual if you have it. Good luck.
Mar 16, 2009 | Ricoh Aficio 355 All-In-One Laser Printer
Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature. turn off the unit. Take the fuser out and reseat it. Power it back up. Ricoh Printers Error Codes Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Dec 15, 2008 | Ricoh Aficio C811DN-T1 - printer - color -...
RICOH AFICIO 650 WHAT DOES THIS ERROR CODE MEANS SC543-00
Try changing the termistor, must be damaged. and reset by total clear, 107 and press and hold the clear stop key more of 3 seconds.
Dec 03, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh CL4000DN Laser Printer Logo
1,298 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
