Question about Sony Cell Phones
I'm having trouble's with the micro usb charger, i've had 3 charger so far. They keep on brakeing and not charging my phone
  • taniwharau82 May 25, 2011
    sony ericsson xperia X10
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 104 Answers
What phone
Posted on May 24, 2011
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
My kindle will not charge
Use a different charger - se if any of the ones you have for your phones are Micro USB - they will charge it fine.
If not get a usb/micro usb cable or micro usb charger from most shops in the high street for 4 or 5 pounds.
If using the usb jack on a pc or laptop swap to a different usb jack on the pc or laptop
Feb 28, 2014 | Amazon Kindle 3G
Jawbone up wont charge
It may be the problem of the charger or the battery, please check them. If the battery is unable to charge or keep charge then replace it.
If the charger is unable to supply sufficient charge or no charge then replace it with a new one.
Jan 13, 2014 | Young Micro Ultra Slim Hard Shell...
I don't have money for a new charger.... Watch
Chargers can be bought mostly though Amazon.com. If you can find them, you can search through the prices of cheap, replacement chargers. If your device has a common USB connector (I.e. type a, type b, micro a, micro b, mini a, mini b) you can find a generic substitute to similar plugs. Even my PSP and Kindle has had similar troubles because USB chargers seem to have a glitchy lifespan. Make sure to not mess up the system's charge port, my DS's port seems to differ from other USB chargers(Type B).
Jun 15, 2013 | Video Game Consoles & Games
The usb for charging but it is not charging.
are you using the charger that came with the phone? I ask because I've run into in the past that if you try and use a different charger it may not work on your phone. you should use the one that came with the phone. having said that, you might want to try a different usb charger if that doesn't work it's probably the battery. Li-Ion batteries have charging circuits built in that can fail and also prevent the battery from charging if it's gone bad.
Nov 09, 2012 | Sony Ericsson Xperia Arc
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Micromax x225 is showing low signal
Ever looked at the power specifications of a mobile charger?? well if not, then have a peek... u will read that the output voltage is 5V DC........ the computer USB also has a voltage output of 5V DC........... any USB based electronic device needs this power to get started.... The laptop coolers u get basically work on this power from the USB... U'll notice that the USB ports have 4 terminals.... the extreme outer side are the POWER terminals +ve and -ve..... the middle 2 are the BUS lines IN and OUT.... a BUS is something electric conductive that allows the flow of 0's and 1's or rather high and low voltages to pass(Basic IT theory).... so this 5V DC can be used for doing anything; charging the mobile phone battery to lighting up entire rooms with LED's, making laptop coolers, etc......... Every mobile phone which has the USB connectivity option gets charged when plugged in... so sometimes even if u dont have the Mobile charger dont panic, find a computer and plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which charge by connecting it to pc. Only nokia phones don't get charged. it is a good feature don't worry
Feb 24, 2012 | Nokia Cell Phones
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
Hi, I'm having trouble charging my Nokia 6300i with a USB cord into a wall outlet with a charger similar to the apple wall charger. I haven't used the phone in over a year and i'm not sure...
Good day!!!
if you phone is not used over a years that can cause a lot of problem like the battery is gone or its drain because it not used for a long time..
I think that is your problem..try to replaced the battery to fix your problem..
thank you for using fixya...
have a nice day!!!
Jun 30, 2011 | Cell Phones
Cell Phones Logo
Top Sony Cell Phones Experts
M_Butkus
marykitty63
Nagendra Baliga
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
